Author Topic: 7.79@175.9 no nitrous no turbo no blower  (Read 4969 times)
« on: July 16, 2004, 18:20:59 »
Traditional Pontiac Power
http://www.rexracing.com/downloads/files/782.mpg
Ride along on a 7 second pass
http://www.rexracing.com/downloads/files/14Rex.wmv
This is a normally aspirated 517 cu in Pontiac engine..
NO BLOWER NO NITROUS NO TURBO
Best ET 7.79 Best MPH 175.94
Click HERE to see timeslip
Go to our Downloads section to see videos
IA aftermarket block 3.25" main
4.350 bore Ross pistons
4.350 stroke Moldex billet crank
Comp Cams roller cam
GRP aluminum rods 6.800" long
Ferrea .990 pins
Total Seal "classic" rings .043 1/16 3/16
Comp Cams .180" offset roller lifters
T&D rocker shafts
Wenzler Super Chief heads 420cfm
Titanium 2.30 &1.80 valves
Wenzler Gutstam cast aluminum intake
2 Pro Systems 1050 Carbs
MSD crank trigger
2 1/8" custom headers by Jack Gaydosh
Powerglide 1.76 transmission
6000 rpm stall ATI converter
4.30 gears
17x 33 Goodyear 2556 tires
« Reply #1 on: July 16, 2004, 20:26:22 »
I´ll see your Poncho with a 815cid Ford HEMI N/A Power
6.56 @ 213mph
 :D
« Reply #2 on: July 16, 2004, 20:29:35 »
Hvernig get ég gleymt þessu
« Reply #3 on: July 16, 2004, 23:37:45 »
Já sko 517cid á móti 815cid en fínn mótor sko alveg hundfínn..
« Reply #4 on: July 17, 2004, 02:06:25 »
Kaase hefur smíðað 498cid sem hefur farið í 6.70´s en já...þessar 815cid HEMI´s eru HRIKALEGAR. Hann smíðaði líka hraðskreiðasta Mountain Motor Chrysler HEMI-inn í Pro Stock :)
« Reply #5 on: July 21, 2004, 15:53:52 »
Quote from: "Einar K. Möller"
OK kannski er ég einhvað sjónskertur eða er engin panna og eru olíu leiðslur beint inn á kjallarann (closed system) :shock:
« Reply #6 on: July 21, 2004, 16:24:54 »
Low Profile Dry Sump Panna :)
