Author Topic: bremsukaflavinnubrögð  (Read 3745 times)
« on: March 25, 2006, 18:29:17 »
Með lengingu brautarinnar verður vonandi hægt að nýta sér einhver þessara ráða.. velji hver fyrir sig
 http://www.v8buick.com/showthread.php?t=97548
 http://www.yellowbullet.com/forum/showthread.php?t=6920
 þurfa ekki allir þessir fljótustu hér heima að hanga á mótornum á bremsukaflanum?
« Reply #1 on: March 26, 2006, 00:21:38 »
það getur nú ekki verið mjög holt fyrir þá sem eru með álstangir  ???
« Reply #2 on: March 26, 2006, 00:30:18 »
Off topic;
Tekið af yellowbullet foruminu, þokkalega óheppinn:
 I've see 400's blow right apart when going to neutral, and years ago I have a 400 standard shift partern just put the trans in and went street racing always shifted into neutral after the pass, well my dumb ass didn't tighten the outer cable and it went into reverse can you say OUCH! riped the bell housing off the block, riped the trans mount off, broke the drive shaft in two, now I had a hoop but it split in the middle so any ideas what a broken drive shaft attached to the rearend in a car still going over 125 MPH can do? lets just say I wasn't waiting for the car to stop I started crawling out the window NOT FUN on the up side I didn't need a single tool to remove the trans
« Reply #3 on: March 26, 2006, 01:49:51 »
sleppa því þá bara að fá sér álstangir ef þær virka ekki í mótora sem eru notaðir annað en eingöngu kvartmílu... Eða ef maður ætlar að smíða mótor sem er 100% keppnis að hafa þá keppnis drifrás sem leyfir svona lagað.
