Author Topic: Chevrolet Camaro Dick Harrell Edition  (Read 4597 times)
Offline Geir-H
« on: February 18, 2007, 18:27:52 »
Dick Harrell Camaro,
Þessi bíll er tribute til Dick Harrell. Þessi bíll er smíðaður af GMMG
Fyrir þá sem vilja vita hver og hvað Dick Harrell er þá bendi ég á www.dickharrell.com
LS6 GM Performance Parts Engine
FIKSE 18"x12" Rear & 18"x11" Front Wheels
GoodYear 335/30ZR18 & 295/35R18 Rear Tires
Custom Charcoal Suade Seat Inserts with stitched "DH Logo" in the Headrest
Chambered Exhaust System with Stainless Tips
Carbon Fiber Type Air Box Lid with 99' GM A.I.R. Filter and Tube
Underhood Coolant and Emission stickers
Front & Rear Eibach Lowering Springs 1.5"
Koni Adjustable Drag Shocks
Corvette Brakes with Hawk Pads & Slotted Corvette Rotors
CNC Ported, Cast Gray Painted, Exhaust Manifolds
Under Drive Pulleys & Belts
Special Front Sway Bar & 1LE Rear Sway Bar
Ported Throttle Body, with 180 degree thermostat
GM Power Antenna & Rear View Mirror with Compass, Temperature and Auto Dimmer
Dick Harrell Stripe Package (Hood and Side Stripe in Carbon Fiber Style)
GM - Wide Body Kit with Gold Bowtie in Grille
Sub Frame Connectors
Dick Harrell Vintage Fender Emblem
New Hi-Flow M.A.F. Housing
Black or White Hurst Ball with Short Throw Shift-Stick
Berger SuperCar/Dick Harrell Edition, Numbered Dash Plaque
GMMG Numbered Door Jam Plate
Car Numbers on Front Window & Rear View Mirror
Key Fobs, Car Cover & Floor Mats with Dick Harrell Logo
Silver Face Gauges with Dick Harrell Logo
Painted Rear Panel (black), with High Polished Stainless "CAMARO" Letters
Painted Roof Tops Body Color
Mobil 1 Oil Fill Cap & Mobil 1 Under Hood Decal
Lightweight Flywheel
GM - Red Performance Plug Wires
Lower Control arm Bracket, and Rear Jounce Bumper Spacers
Rear End Gears - 3:73, 4:10 or 4:56
Dyno Sheet with Engine Tuning
Kooks 1 7/8-inch long-tube headers, 3-inch Y-pipe, and high flow cats are unique to this project. However, the QTP electric cutout and GMMG cat-back were such a perfect combo on the ZL1s that GMMG owner Matt Murphy decided to implement them here as well.
With the help of GMMG body man Keith Lanning, Ron did some custom body work such as filling in the antenna hole and extending the wheel houses by 2.5 inches. Unlike the regular Dick Harrell cars, Ron required the stock .75-inch lip to squeeze in the 28x10.5-inch slicks. As a drag car, it also deviates from the GMMG exhaust setup by using a set of Kooks 1 3/4-1 7/8 stepped race headers to empty directly to the atmosphere.
Interiors are kept mostly stock aside from the Dick Harrell badges, floormats, white gauge faces, and suede seat inserts. Six speed cars also have a shortened stick on the stock shifter with a Hurst white ball knob. The owner of this car, Valerie Harrell (daughter of Dick Harrell), also opted for the Wolfe roll cage for safety and NHRA compliance.
GMMG moved all of its bodywork in-house to assure all 30 cars would be fitted properly with the new panels and repainted in a timely fashion. Murphy says they churn out about one car per month, which means they should be finished by the time you read this. Matt designed the graphics based upon a modern interpretation of Dick's 1970 Funny Car, and when he consulted Valerie, she assured him that the use of carbon fiber accents were very much in the spirit of her father's lust for new technology. Painting was dependent upon the customer and the base color, however, in the case of this car Valerie had family friend Bill Carter apply a custom Butterscotch Orange. Along with Matt Berger's green Camaro, this is one of only two cars not painted by GMMG.
Just like production cars such as Valerie's, Ron went with the Strange 12-bolt rear except that he uses 35-spline axles instead of 33-spline, 4.88 gears instead of 4.10s, and a spool rather than a posi.
Bogart Pro-Stars and Mickey Thompson skinnies help shed some front end weight along with a manual steering rack and Strange drag brakes.
While he chose to leave Dick Harrell's nickname "Mr. Chevrolet" off the spoiler, Ron did put it on this custom seat cover along with his signature. Even though it is a drag car, Ron worked hard to stay as faithful to the production car as possible. The output for the 347-cube motor is right on par with the Phase III 427s at 630 hp (or 507 hp at the wheels through a stout driveline). Except in a 2,920-pound racecar with a transbrake and plenty of traction, this equals 1.36 60-ft times and a 9.72 ET at 137 mph. These kinds of time slips require a spec Wolfe roll cage and a Kirkey racing seat.
To fill out those enlarged fenders on the widebody kit, GMMG chose the classy Fikse Profil 13s measuring a boggling 18x11 front and 18x12 rear. When mated to your choice of either Michelin Pilot 295/35ZR18 and 335/30ZR18 or BFG G-Force and drag radial combo that makes for one enormous contact patch. As with the ZL1s, GMMG also upgrades the front brakes to Corvette specs.
GMMG was not shy about placing the Dick Harrell name all over its latest supercar, which is just fine by anyone who ever knew Dick. A former technician and race team member from '68-69 as well as family friend, Dave Libby, said the car was "a fitting tribute that I know Dick would have been proud of. It's tasteful and not garish ... it's the best-looking Camaro I've ever seen. It's incredible to have a car like this that can run in the 10s with air conditioning, and is drivable with reasonable gas mileage
Though Ron tries to keep the interior stock appearing, he has stripped weight wherever possible. HVAC controls are gone as are the radio, rear and passenger seats. The center console as you can see is still intact, which took quite a bit of modifying to allow the use of a B&M Pro Ratchet shifter.
Dick Harrell was one of the first people to start shoehorning 427s into Camaros back in the late '60s (before the introduction of the ZL1), so it is all the more fitting that this C5R-derived 427ci LS1-powered Camaro bears his name. All Dick Harrell Edition cars also bare the signatures of Harrell's crack staff from his shops in St. Louis and Kansas City. Similar to GMMG's ZL1s, the Harrell Edition cars also boast ported Holley intakes, Whisper carbon fiber airlids, air conditioning, and full emissions controls. While the big 244/248 duration cam tends to run a bit dirty, the Camaros will still pass the emissions readiness test. The objective was not only creating one of the baddest Chevys ever made, but also to create a drivable, livable car that wouldn't just sit in the garage.
Unlike the production Dick Harrell cars, Ron's pilot car has a painted FAST intake, Nick Williams 90mm throttle body, Futral Motorsports-built solid roller 347, and runs off a Speed Density tune. The custom hand-ported LS6 heads are from Meaux Racing in Abbeville, La., which Futral uses on all its serious builds
Smá upplýsingar um bílana sá Orange litaði
Car: 2002 Camaro Dick Harrell Edition Prototype
Owner: Valerie Harrell
Block: C5R, 427 cubic inches
Compression ratio: 12.5:1
Heads: LS6, ported and polished by TEA, 2.05 intake, 1.60 exhaust valves
Cam: COMP Cams hydraulic roller, 244/248 duration at .050, .612/.615-inch lift
Pushrods: COMP Cams Hi-Tech 7.400-inch
Rocker arms: Stock 1.7 ratio
Pistons: JE forged
Rings: JE
Crankshaft: Callies forged
Rods: Oliver
Throttle body: Stock, ported by GMMG
Fuel injectors: Accel 36 lbs/hr
Fuel pump: BBK
Ignition: Stock coil on plug, NGK TR55 plugs
Engine management: Stock, tuned by Mike Carnahan of GMMG
Exhaust system: Kooks 1 7/8-inch long-tube headers, high flow cats, 3-inch Y-pipe and GMMG cat-back with electric cutout
Transmission: T56
Clutch: Z06 clutch and pressure plate, SPEC flywheel
Driveshaft: 3-inch chrome moly
Front suspension: Eibach springs, Koni shocks, GMMG sway bar
Rear suspension: Eibach springs, Koni shocks
Rear end: Strange 12-bolt, 33-spline axles, 4.10 gear, posi
Brakes: Corvette front brakes, stock rear
Wheels: Fikse 18x11 front, 18x12 rear
Front tires: Michelin Pilot 295/35ZR18
Rear tires: Michelin Pilot 335/30ZR18
Fuel octane: 93
Best ET/mph: 10.94 at 125
Best 60-ft. time: 1.46
Current mileage: 500
Hinn bíllinn er aðeins meira Race
Car: 2000 Camaro Z28
Owner: Ron Mowen
Block: 2002 LS1, 347 cubic inches
Compression ratio: 14:1
Heads: LS6, ported and polished by Meaux Racing, 2.055 intake, 1.60 exhuast valves
Cam: Cam Motion solid roller, 259/267 duration at .050, .724/.704-inch lift, 108 LSA
Pushrods: Futral Motorsports
Rocker arms: T&D 1.7 ratio
Pistons: Diamond forged
Rings: Hellfire
Crankshaft: Stock
Rods: Lunati Pro Mod billet
Throttle body: Nick Williams 90mm
Fuel injectors: Ford Motorsport 42 lbs/hr
Fuel pump: Walbro 255lph
Ignition: Stock coil on plug, NGK TR6 plugs
Engine management: Stock, tuned by Futral Motorsports
Exhaust system: Kooks 1.75 to 1.875-inch stepped long-tube headers
Transmission: TH400 built by Rossler Performance Transmissions
Torque converter: TCI 8-inch, 6200-stall
Front suspension: PA Racing tubular K-member and A-arms, Hal coilovers, no sway bar
Rear suspension: HAL shocks, V-6 springs, Wolfe lower control arms, torque arm, panhard bar and swaybar
Rear end: Strange 12-bolt, 35-spline axles, 4.88 gear, spool
Brakes: Strange front and rear drag brakes
Wheels: Bogart 15x3.5 front, 15x10 rear
Front tires: MT ET Front Runners 26x4.5
Rear tires: MT ET Drags 28x10.5
Fuel octane: 112
Race weight: 2,920 pounds
Best ET/mph: 9.72 at 137
Best 60-ft. time: 1.36
Geir Harrysson #805
Offline ljotikall
    • http://kvartmila.is
« Reply #1 on: February 18, 2007, 19:23:12 »
sweet ass mófó!!!!
aukalimur#858
ljotikall@visir.is
pontiac = Poor old nigger thinks its a cadillac.
kveðja Guðjón Jónsson
« Reply #2 on: February 18, 2007, 21:31:23 »
Mjög flottir,fíla þennann ljósbláa í videóinu 8)
Offline Geir-H
« Reply #3 on: February 18, 2007, 22:29:01 »
http://gmmginc.net/media/Video/
Hérna er videoið sem að Frikki minnist á rosalega skemmtilegt
Geir Harrysson #805
« Reply #4 on: February 19, 2007, 01:08:39 »
Þessir voru í GM high tech í sumar....
Offline Geir-H
« Reply #5 on: February 19, 2007, 20:30:25 »
Þessum myndum er lika stolið þaðan
Geir Harrysson #805
Offline Ragnar93
nice
« Reply #6 on: February 20, 2007, 14:19:20 »
Flottir!!! :)
Ragnar Björn Jónasson
Mercedes Benz C220 CDI 1998
Mercedes Benz 190E 1990
Mercedes Benz 190E 1988
