Author Topic: CJ7 project...  (Read 2905 times)
Offline vladrulli
CJ7 project...
« on: December 11, 2006, 22:25:20 »
Oska eftir tilboğum i projectiğ - Jeep CJ7 '80 (fornbill)...
vantar skuffu, hitaramotor og framstola til ağ geta klarağ bilinn... allt annağ er til stağar....
şetta er cj7 grind meğ amc360 (edelbrok milli+600cfm Holley), t176, dana300 og dana ağ framan og amc20 meğ heilum fljotandi öxlum ağ aftan...
grindin sandblasin og epoxy-grunnuğ...
grindin maluğ...
ryğfritt mælaborğ...
Partalisti yfir şağ sem var pantağ fra USA (vantar örugglega eitthvağ inn a hann) - mikiğ af ryğfriu og kromi... meğal annars nytt glukkastykki og bensintankur, fjağrir og demparar...
orginal svartir brettakantar
loftsia+hus
DickCepek 2.5 lift kit
front brake piston and rubber kit 80-86 CJ7
Sway-bar linkage for 2.5" lift
amc360 seal kit
amc360 intake manifold seal
speedometer
wiper linkage
gas tank skid plate
heater core
clutch kit
cj heavy duty shackles w/BLACK BUSNINGS
tailgate seal
rear single ss brake line
front pair ss brake lines
hardtop ss liftgate hinges
gas tank sending unit
3 air heat pulls
liftgate cam & cable
cowl weather seal
chrome windshield knobs
cj7 ss entry guards
ss steering wheel column cover
6 aluminium replacement knobs
cj7 defrost ducts
cj7 plastic glovebox insert
1976-80 chrome rear tail lamp right
1976-80 chrome rear tail lamp left
cj volt gauge
cj7 antenna kit
ss inside windshield brackets
locking gas cap
cj7 1976-86 spring plate
defrost duct hose
steering column bearing kit
t176 shifter repair kit
cj7 transmission mount
column firewall seal
tailgate cable
firewall heater motor seal
switch washer
spindle nut socket
spindle nut and washer
ss lower door hinge
Skyjacker 7100 steering stabilizer
shackle end spring hanger
ss windshield frame hinges
steel windshield frame
steel gas tank
cj ss euro guards
cj turn signla lever
AMC 20 axle yoke kit
spicer universal U joint
dana 300 u bolt yoke kit
dana 300 shifter knob & nut
t170 shifter knob & nut
cj rear brake cylinder
adjustable door strap
parking brake rubber pad
cj7 two pedal pads
cj ss hood kit
cj ball joint kit
ss wiper motor cover
cj 76-81 tie rod kit (pitman to knuckle)
parking brake cable
parking brake cable
parking brake cable
ss brake dust covers
front brake pads
gas filler neck
brake caliper dust covers
front park and signal light assemply
stanless grab bar
stainless/chrome liftgate handle w/keys
sidemarker set 2 red pair
 2 amber pair
stanless fuel protector
stainless mirror kit
set of 6 dash lights
windshield washer pump and filter kit
windshield glass seal
stainless glove box door
ignition cylinder and keys
framstykki og afturhleri ur trefjaplasti fra alltplast.net
hefur fariğ mikill timi og slatti af peningum i şetta...
Vil helst selja allt i einu lagi... athuga hugsanlega skipti a odyrari eğa get tekiğ eitthvağ skemmtilegt dot upp i...
fæst ekki gefins og şvi öll bull tilboğ afşökkuğ fyrirfram... ;)
tilboğ i PM
Growing old is mandatory, growing up is optional...
