Author Topic: Bílakaup  (Read 7362 times)
Offline Jón Þór Bjarnason
Bílakaup
« on: February 04, 2005, 20:43:00 »
Ég er að spá í bílakaup. Ég er hér með myndir af 2 bílum sem ég er að spá í. Hvað finnst ykkur ?
For Sale.1958 Nash Metropolitan.
Built 340,727 Trans.,Narrowed 8 3/4 With Mark Williams axles.33x19.5 Mickey Thompsons.Full Rollcage.Aluminum Int.Fuel Cell.Wheelie Bars.Willwood disc brakes.
Car is turn key ready to go.Street,Strip,or Show.Could easily be converted
to big block or Hemi.
S:899-3819
2006 VW Passat 2.0L HighLine
p
« Reply #1 on: February 04, 2005, 20:47:11 »
Þetta er hinn.
Body: Metallic Blue with some red pin-striping. Bumpers and other trim pieces are in excellent condition. Fiberglass life-off hood and Harwood scoop. Lexan windows. Rear wheel wells are flared to accommodate the MT ET 29.5x10.5x15 slicks (brand new). The frame has been tied.
Fuel System: Jazz 4-gal tank mounted in trunk. Electric fuel pump and 3/8 fuel line runs to the 780 Holley, vacuum secondary carb.
Engine: 360 block bored .030. Stock crank was turned, rods checked and assembled using Keith Black pistons (12.8 comp) and Comp Cams .508, 292 Hydraulic cam, springs, lifters, and retainers. Heads have 2.02 valves and were extensively ported on exhaust side and mildly ported on intake side. Moroso 8-qt pan.
Intake: Edelbrock Performer RPM with Mr. Gasket 1" spacer.
Electrical: Optima trunk mounted battery. Emergency cut-off in the rear. New wire throughout the car. Mopar mech advance distributor with new 8mm wires. MSD 6AL.
Exhaust: Coated Hedman Hustler fenderwell.
External Engine Components: New water pump, alt, brackets, pulleys and hoses.
Cooling: Aluminum Griffin radiator.
Transmission: Race-built 727 with reverse manual valve body. MP steel deep pan. 5.0 kickdown lever. HP rebuilt kit with Alto clutches, bolt in rear sprag and HP front RR bands. PTC 3000 stall conv. SCS shifter with line lock.
Rear: 8 3/4" suregrip. Richmond 5:13 gear. Axles are 4" bolt pattern. 3" studs. New brakes throughout. Competition shocks front and rear.
Wheels: Centerline. Front are 15x3.5 and rear 15x 10.
Interior: Fiberglass racing seat with new cover. Roll cage. Shoulder harness needs update. Extensive aluminum work on door panels and rear seat area. Dash modified to install Autometer Oil pressure and water temp gauges. Moroso 5-switch panel. Autometer 5" monster tach with shift light.
S:899-3819
Gizmo
Bílakaup
« Reply #2 on: February 04, 2005, 21:20:21 »
Nash...brútal töff 8)
það vantar svona mikið öðruvísi bíla á götuna hérna heima
Offline Svenni Turbo
Bílakaup
« Reply #3 on: February 04, 2005, 21:51:03 »
Ef þú ert að spá í þessu fyrir einhverja alvöru, og villt álit manna á einhverju fleiru en útlitinu, þá væri nú ekkert verra að láta fylgja smá specs um bílana, svo sem vél og þess háttar auka hlutum.
Got BOOST? If it ain't blown, it sucks...
http://www.cardomain.com/ride/2080537
www.bilmalning.is
Bílakaup
« Reply #4 on: February 04, 2005, 22:21:22 »
Quote from: "Gizmo"
Þessir fara ekki á götuna nema þá bara í Hrauninu upp á braut.
Ég er að skoða fullt af farartækjum sem eru eingöngu keppnis.
Undir hvaða tollaflokk falla svona keppnis tæki undir?
S:899-3819
Bílakaup
« Reply #5 on: February 05, 2005, 00:35:31 »
Engir tollar bara vaskur.
Vefstjóri KK
Þú hefur blessun félagssins
« Reply #6 on: February 05, 2005, 14:19:02 »
Þeir eru báðir flottir. Kaupa strax
stigurh
Bílakaup
« Reply #7 on: February 05, 2005, 17:08:58 »
:shock: Þessi efri er auðvitað sjúkt flottur  :!:
Kaupa strax
Bílakaup
« Reply #8 on: February 06, 2005, 14:21:35 »
Það er soldill verðmunur á bílunum. Sá efri er á $ 11.000
og sá neðri er á $ 6.000 Getið þið eitthvað sagt mér um NASH?
Eins væri frábært ef þið gætuð gefið mér upp síður með
Drag Race bílum á skikkanlegu verði til sölu þá meina ég
ekki einhverja tugþúsundir dollara.   :)  :)  :)
S:899-3819
Bílakaup
« Reply #9 on: February 06, 2005, 15:58:14 »
Quote from: "Nonni_n"
http://www.racingjunk.com/
Bílakaup
« Reply #10 on: February 11, 2005, 23:43:29 »
Jæja ég er enn að spá og spekulera enda soldið langt í næstu keppni. Hér er fáiði smá uppl. um hvað er að gerast í mínum þrönga heimi.
Listing for a friend!!!!! 68 cuda, 440 with worked 906 heads,Roller rockers, 590 mp solid lift cam. 727 with new trans brake, J converter. Fenderwell headers,4150 hp series carb. New aluminum radiator, New front wilwood disc brakes, Front suspension just rebuilt. autometer gauges,MSD 6AL, 2step,line lock, Braced 8 3/4 with 4:56 gear, moser axles,spool. Super stock springs. Good driving and consistent car. Also included is a stock 383 engine and he has a good set of rods and pistons from a 452ci 440 engine he had. Not sure what brand they are. I'm thinking eagle rods and Ross pistons but don't hold me to it.
S:899-3819
