Author Topic: Top Fuel Drag Racing Put Into Perspective  (Read 3925 times)
Offline Doctor-Mopar
« on: January 14, 2005, 22:30:00 »
Tók þetta af síðunni hjá moparengineswest. Nokkuð athyglisvert
Top Fuel Drag Racing Put Into Perspective:
* One Top Fuel dragster makes more horsepower than the first 4 rows of the Daytona 500.
* At full throttle, a Top Fuel dragster consumes 11.5 gallons of Nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate but produces 25% less energy.
* A stock 426 HEMI does not produce enough horsepower to drive a Top Fuel supercharger
* At full throttle the supercharger is ramming 3000 CFM of air into the cylinders.  The mixture is so compressed that the engine is on the verge of hydraulic lock.
* Nitromethane burns yellow.  The white flames seen above the exhaust stacks is actually Hydrogen, which has been dissociated from water by the heat of combustion.
* At stoichiometric, the nitromethane air/fuel ratio is 1.7:1.  Flame front temperature is 7050 degrees.
* The dual magnetos produce 44 amps to each plug.  This is enough current to arc weld.
* Spark plugs are totally consumed during a run.  In fact, after half way, the engine is dieseling from the compression and the glow of the exhaust valves.  After this point, the engine can only be shut down by cutting the fuel flow.
* To accelerate to over 300 MPH in 4.5 seconds the dragster must average 4 Gs. For the dragster to reach 200 MPH by half-track required 8 Gs.
* A Top Fuel engine only turns approximately 540 revolutions from light to light.  Including the burnout, the engine must survive only 900 revolutions!
* Redline is quite high at 9500 RPM.
* Assuming all the equipment is paid off, the crew is working for free, and nothing blows up, each run costs $1000 per second.
Perspective:
So you take your specially tuned $140,000 Lingerfelter “Twin Turbo” Corvette, and start back about a mile or so, accelerating as fast as you can, reaching your top speed of 200 MPH.  This is really moving and would be something anyone would be proud of.  You’re approaching the starting line where the Top Fuel dragster is sitting – stopped – waiting for you.  As you cross the starting line, the light turns green.
Within 3 seconds you are deafened by the incredible whine of the dragster, which has caught up to you.  He passes and beats you to the end of the 1320-foot quarter mile.
THAT  is acceleration …
Þórhallur Kristjánsson
Gizmo
« Reply #1 on: January 14, 2005, 22:37:45 »
Þetta er mikið........ :shock:
Rúmir 40 lítrar á sek....og kertin brunnin upp eftir eitt rönn.
« Reply #2 on: January 14, 2005, 23:44:21 »
þetta er ekkert! MR2 túrbó mundi rústa þessu
Offline 72 MACH 1
« Reply #3 on: January 15, 2005, 00:25:24 »
Þetta er bilun……
…………þú ert að ná hámarkshraða á um 200 mph = 320 km/klst. Þú ert á góðri ferð og þetta er nú eitthvað sem allir geta varið stoltir af. Þú nálgast ráslínu þar sem Top Fuel dragsterinn stendur – stopp – bíður eftir þér. Þegar þú ferð yfir ráslínu veður rásljósið grænt. Innan 3 sekundna verður þú fyrir varanlegum heyrnarskaða vegna yfirþyrmandi hávaða frá Top Fuel dragsternum sem hefur náð þér. Hann fer fram úr þér og vinnur þig á 1/4 mílunni = 402 metrum.
Þetta er hröðun……
Kveðja,
Eggert Kristjánsson.
« Reply #4 on: January 15, 2005, 00:36:02 »
Eyrun í mér eru nú ennþá í lagi síðan ég fór á NHRA Gatornationals 2002 og sat í VIP Stúkunni hjá Mac Tools (við endalínu). Mér datt ekki í hug að taka fyrir eyrum... gotta love that noise....skemmtilegast fannst mér að finna titringinn sem kom þegar þeir þustu framhjá á 320+ mph.
Ég á fulla hillu af pörtum úr vélum og skiptingum í svona Top Fuel Dragsterum og Funny Cars, sumt sem hefur ekki alveg lifað af... og ég er að fá meira af hlutum... sem sumir ekki lifðu af... alveg snarmagnað.
« Reply #5 on: January 15, 2005, 09:41:40 »
:shock:  VÁ VÁ  Þvílíkar græjur
Offline geysir
« Reply #6 on: January 15, 2005, 19:10:00 »
Ansi magnað maður.
Djöfull hlýtur að vera magnað að þrykkja einu svona tæki. Þ.e.a.s Top Fuel dragster. :shock:
Atli Þór Svavarsson.
