Author Topic: Kraftmikill magnari.  (Read 2110 times)
Offline gtturbo
« on: December 02, 2004, 17:11:44 »
Til sölu er magnari að gerðinni DLS. Hann er sama og ekkert notaður og var keyptur í sumar.
Hér að neðan er hægt að lesa um hann.
ULTIMATE series A7 Five-channel amplifier rated at 4 x 60 Watts on the stereo channels plus 1 x 300 Watts from the mono sub channel.
Built to provide a complete in car entertainment system system with all necessary crossovers, all in one amplifier. For detailed information about the crossover possibilities please read the technical specifications.
Internal switches connects all amplifier inputs if you prefer to use only one RCA cable.
Built-in fan control. Remote sub level control with phase shift is included.
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
Mode : AB
Number of channels : 5
Nominal power in 4 ohm : 4 x 60 W
Nominal power in 2 ohm : 4 x 100 W
Mono channel, nominal power in 4 ohm : 300 W
Mono channel, nominal power in 2 ohm : 440 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,3 - 7 V
Filter ch. 1 & 2 : Highpass: 80 - 400 Hz / 1,6 - 8 kHz (x20)
Filter ch. 3 & 4 : Highpass: 80 - 400 Hz. Lowpass 0,3 - 4 kHz / 3 - 40 kHz (x10)
Filters mono sub channel : Lowpass: 50-125 Hz.
Terminal for external cooling fan : Yes
Phase control : 0-180 degrees continuously
Remote sub level control with phase shift : Yes
Dual DC-inputs : No
Current draw, idle : 1,1 A
Current draw, maximum : 120 A
Dimensions W x D x H : 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inch)
Weight
: 8,1 kg ( 17,86 lb)
Ásett verð á magnarann er 69.900kr.
Áhugasamir sendið mér einkapóst eða hringið í síma 863-9443
Úlli
Impreza turbo 2 seldar
Ford F350 MY03 seldur
Audi A4 1.8T ´00 seldur
MMC Lancer Evo 8 ´04 2 seldir
Nissan Double Cab ´03 seldur
Toyota Corolla Si seld
Volvo S40 T4
