Author Topic: Til sölu nır 750 blöndungur.  (Read 2690 times)
Offline 72 MACH 1
« on: October 21, 2004, 10:56:05 »
Til sölu nır blöndungur.
Verğ: 35.000 kr.
Gunnar.
8999423.
Carburetor, Gasoline, Performer, Universal, 750 CFM, 4-Barrel, Auto Choke, Single Inlet, Silver, Each
Edelbrock's Performer carburetors feature two-piece, all-aluminum construction for cooler operating temperatures and less warping. There are no gaskets below the fuel bowl level for fewer leaks, and no plastic parts or power valves to blow out. The carbs use easily changed metering rods for precise tuning, and the primary venturi booster is a bottom-feed design for smoother acceleration and better drivability.
Edelbrock
Edelbrock Performer Carburetors
Number of Barrels: 4
Carburetor Flange: Square bore
Choke: Auto.
Fuel: Gasoline
Secondary Type :Air valve
Fuel Inlet :Single
CFM 750
Carburetor Finish Silver
Ford Kickdown No
Throttle Linkage Type Universal
