Author Topic: 2002 Ford SVT F150 Lightning  (Read 13625 times)
Offline andyzx7r
« on: July 05, 2017, 21:13:06 »
For Sale...
5.4 2V Supercharged Intercooled V8 Engine
400hp 610nm of Torque 5sec from 0-60
milage 133.xxx miles
RWD
Changed
New Engine Oil
New Supercharger Coolant and Oil
New Spark Plugs and Coils
New Vacuum Lines
New K&N Cold Air Kit
New IAC Valve
New TPS Sensor
New EGR Valve & EGR Valve Control Solenoid with EGR Pressure Feedback Sensor plus both hoses
New PCV Hose & Valve
New Plenum gasket /plenum and Intercooler cleaned/
Oil separator mounted
New Fog lights
New High Performance Sloted and drilled rotors with carbon fiber pads in all four corners
New MICHELIN tires all for corners /500km done from a change/
Bed painted with LineX
More specs...
5.4L 2V Triton Supercharged Intercooled V8 engine
Modified 4R100 4–speed automatic transmission with OD lockout
Limited-slip differential with auxiliary transmission fluid cooler
Eaton supercharger 112, Generation IV (8 psi) mechanical boost
Heavy Duty Engine super cooling system
Power steering cooler with Fail-safe cooling feature
9.75 in limited-slip differential with 3.73:1 final drive ratio
Aluminum driveshaft with hardened yoke
18 in x 9.5 inaluminum 5-spoke SVT Signature wheels
Bilstein monotube front and rear shock absorbers
Outside rear view mirrors with integral turn signal
Unique electro-luminescent instrument cluster with SVT signature 140 mph speedometer, tachometer, oil pressure, temperature, fuel, supercharger boost gauges white-faced gauges, including vacuum/boost gauge
Standard 6–way power driver's seat
Accentuated seat back and cushion lateral bolstering
Leather-wrapped door trim inserts
Premium In-Dash Six CD Sound System
Dark tinted sliding rear window
Sun visors with illuminated mirrors
Key pad entry
Dual-stainless steel exhaust system with side rear exit
Unique front fascia with integrated round fog lamps
Unique upper and lower grilles
Unique front lower air deflectors
Unique cab rocker and lower box moldings
Unique high-mount stop lamp/cargo lamp
4-wheel ABS/4–wheel disc brakes
Unique 60/40 leather/cloth seats
Class III trailer tow pkg-inc: 7-pin trailer wiring harness, frame-mounted weight-distributing hitch
Locking glove box
Manual air conditioning
Premium electronic AM/FM stereo radio w/cassette, 6-disc CD changer-inc: digital clock, premium sound w/amplifier, (4) speakers, speed compensated volume control
Pwr windows w/driver side one-touch down/delayed accessory pwr
Securilock anti-theft ignition
Tilt steering column
Car drives and run like new, no tire kickers or timewasters please...
Will change for a nice Jeep Grand Cherokee /prefer a ZJ platform/ with a minimum million in cash on top from a buyer...
1.000.000 isk
Andy 8479128
« Last Edit: August 04, 2017, 11:20:02 by andyzx7r »
Go for it...
Offline andyzx7r
Re: 2002 Ford SVT F150 Lightning
« Reply #1 on: August 12, 2017, 15:45:37 »
SOLD
Go for it...
