Author Topic: Hringakstur - almennar reglur  (Read 4311 times)
Offline SPRSNK
« on: April 02, 2016, 12:53:46 »
Almennar reglur til hliðsjónar fyrir hringakstur/Time Attack
Bílar þurfa vera með skráð VINnúmer eða grindarnúmer AKÍS fyrir sérsmíðuð keppnistæki.
Keppnistæki þurfa að vera með viðeigandi vátryggingar í gildi.
Hjálmaskylda skv. reglum AKÍS:
http://www.ais.is/wp-content/uploads/2013/04/L25_standards_for_helmets_3.pdf
Með fyrirvara um frekari breytingar.
PRE EVENT VEHICLE SAFETY CHECKLIST
 Always remember Motor Sport Can Be Dangerous
 It makes sense to minimise the risk
 When you participate in this event you will be required to sign an indemnity form upon which you make the declaration that the vehicle you are using is in a safe condition for high speed circuit use.
 Whilst we will not be scrutineering vehicles we always reserve the right to deny circuit access to any vehicle we consider to be a risk to the occupants or other track users.
 Unless your vehicle is a competition vehicle suitably prepped for its class then vehicles should be in a roadworthy condition.
 We suggest that you carry out these few simple checks to make your day safer and everyone elses ultimately more enjoyable. Sort any problems found prior to participating.
Brakes
 Check fluid levels. & for excessive pedal travel and investigate cause if found.
 Check thickness of linings. If they require renewal it is best to do this well in advance and ensure pads etc are bedded in prior to taking to the circuit.
Suspension, Wheels & Tyres
 Remove wheel trims if fitted.
 Check condition and suitability.
 Check pressures.
 Check wheel nuts are tightened.
 Seats and Seat Belts
 Check condition and that mountings are secure.
 Make sure all occupants know how to adjust these to give maximum safety and comfort.
 Suspension and Steering
 Check suspension for condition and operation.
 Check for play in joints, linkages, bushes etc.
 Investigate any noises or play in wheel bearings.
Engine Bay
 Check Engine Oil and Coolant Fluid levels ( DO NOT OVERFILL)
 Check condition of hoses and pipes.
 Check for and correct fluid leakages.
Electrics
 Check battery is securely mounted and terminals are covered by an insulating material.
 Check wiring for condition and potential chafing, short circuits etc.
 Check Wipers for condition and operation.
 Check lights for operation. (in dull or wet conditions you may be denied track access if lights do not work).
Fuel
 Check for and rectify any leaks.
 Check Filler cap for security and seal.
 DO NOT overfill the tank (This is a particular problem with Kit Cars).
 DO NOT underfill the tank ( running out of fuel on circuit will stop that session for everyone and may result in you being denied any further circuit access for the rest of the day).
 Use safe practice if refuelling from cans.
 Only use correct containers for fuel.
Interior
 Check Seats and Seat Belts. Mountings and condition.
 Consider if the use of Full Harness Belts is appropriate without full rollover protection.
 Removing the interior is NOT recommended. If it is removed then ALL sharp edges and window mechanisms etc must be covered with impact absorbant material.
Bodywork
 Must be in a sound condition with no sharp edges, obvious corrosion or dangerous protusions. Both internally and externally.
 Roll Over protection is advisable in any vehicle used on a circuit but is strongly recommended for all open top or non permanently fixed roof type vehicles.
 Remove all loose or non-permanently secured objects from the vehicle.Security Devices, Door Locks, Immobilisers etc. Ensure these are set to allow unimpeded use and access to the vehicle whilst in the assembly area or on circuit.
Safety
 The carrying of an adequately secured, readily accessible and fully charged “AFFF” type Fire Extinguisher of a minimum 1.75 litres is strongly recommended.
 All limbs should be covered whilst on circuit. Ideally the material worn should be made of tough natural fibres cotton, wool etc. Remember man made fibres unless designed to be flame resistant tend to melt in the event of fire.
 The wearing of flame retardant clothing although not manadatory is strongly recommended.
« Last Edit: April 02, 2016, 13:00:58 by SPRSNK »
Offline SPRSNK
Re: Hringakstur - almennar reglur
« Reply #1 on: April 13, 2016, 00:11:52 »
Time attack á laugardaginn
Þátttökugjald er 5000 kr.
 Mæting keppenda klukkan 11:30
 Skráning fer fram í stjórnstöð.
Milli klukkan 12 og 13 verður farið yfir öryggisatriði, labbaður hringurinn sem keyrður verður og ekinn prufuhringur með undanfara.
 Keyrsla hefst klukkan 13 og verður keyrt til klukkan 17.
 Keyrðar verða 10 mínútna lotur.
 Skipt verður milli hjóla og bíla, 3 lotur í senn.
 Keppendur eru að keppa við sinn eigin tíma.
Öryggispunktar:
 Þátttakendum er bent á að notast við nýjan bremsuvökva með hærra suðumark(keppnis bremsuvökva).
 Hjálmaskylda - hjálmur þarf að vera löglegur samkvæmt fyrirmælum AKÍS.
 Dekk þurfa að vera í góðu ástandi.
 Bílar á númerum þurfa að hafa staðist bifreiðaskoðun hjá skoðunarstöð.
 Engir vökvar mega leka úr tækjum sem taka þátt. Ekki fæst rásleyfi ef leki kemur upp á ökutæki.
Leyfi þarf hjá keppnisstjóra fyrir myndatöku utan áhorfendasvæða.
Góða skapið skylda og munið að allir eru að læra, ökumenn sem og starfsfólk! :-)
« Last Edit: April 13, 2016, 00:13:28 by SPRSNK »
Offline SPRSNK
« Reply #2 on: April 13, 2016, 02:12:28 »
Hringakstur á laugardag kl 11:30 - sjá FB viðburð:
https://www.facebook.com/events/1650345158538665/
