Author Topic: snilldar græjupakki til sölu  (Read 3917 times)
Offline Durgur91
« on: January 14, 2015, 19:06:49 »
ég er með þrusugóða 12" Ground zero keilu í boxi sem er um 800w rms og svo audiobahn magnara sem er 1000w rms sem er ennþá ný í kassanum (keilan drap síðasta magnarann sem var 800w rms og þetta var komið úr bílnum áður en ég fékk mér annan magnara) og það er coax tengd fjarstýring fyrir magnarann og svo fylgir með þéttir annars stútar þetta snilldar tvíeyki alternatornum hjá manni...
Keilan:
Model                    GZHB 30XBT
Diameter                300 mm / 12"
Boxtype                 Basstunnel
Volume Net             45 L / 1.59 cu.ft.
Dimensions              570 x 380 x 420 (300) mm / 22.4“ x 15“ x 16.5“ (12“)
Woofer                   GZHW 30X
Power Handling        800 WRMS
Impedance              2 x 2 Ohm
Frequency response  35 - 100 Hz
Adjustable low pass filter
Phaseshift switch
Bass remote
High level input
Illumination
Plexiglas Front mit weißer LED Beleuchtung / Plexiglass front with white LED light
magnarinn:
    Monoblock Class AB Intake Series Car Amplifier
    RMS Power Rating:
        4 ohms: 500 watts x 1 chan.
        2 ohms: 1000 watts x 1 chan.
    PWM MOSFET power supply
    Large display volt meter with blue illumination
    Bass Boost on/off switch
    High gloss chrome-plated finish
    Mono channel operation
    Throughput RCA connections
    Cobalt blue illumination
    Double-Sided glass epoxy circuit board
    Air-Induction groove and air intake fan help force cooler outside air into the chassis of the amplifier and help to maintain its optimum operating temperature
    Chrome flame fan grilles for an enhanced appearance
    3-way Protection Circuitry: Thermal, Short Circuit and Overload
    Heavy duty aluminum alloy heatsink for extreme heat dissipation
    Nickel-Plated RCA level inputs
    Nickel-Plated block terminals
    Input Sensitivity: 200mV-8V
    Variable Low-Pass Filter (50-120 Hz, 18 dB/octave)
    Subsonic Filter (20-50 Hz)
    Frequency Response: 10-40,000 Hz
    THD: 0.02%
    Signal-To-Noise Ratio: >100 dB
    Dimensions: 11-7/8"L x 11-3/16"W x 2-1/8"H
    4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
    1-year Manufacturer's warranty
ein mynd af þéttinum (bláa snúran er +12v fyrir display sem sýnir voltin á kerfinu)
og svo ein mynd af fjarstýringunni:
er að selja þetta því að stuttu eftir að magnarinn fór og ég fékk annað í staðinn þá seldi ég bílinn sem þetta var í og fékk mér jeppa sem ég tímdi ekki að setja þetta í... núna á ég bíl með skottplássi en hinsvegar lítið barn líka sem kémur alltaf með þannig að ég hef ekkert við þetta að gera og er bara búið að vera niðri í rakalausri geymslu síðan
þessi pakki kostaði rúm 200þ. þegar ég keypti þetta fyrir utan snúrukitt og boxið og þéttirinn voru í bíl í ca 2 1/2 mánuð og magnarinn ennþá í kassanum þannig að mér finnst réttlætanlegt að setja á þetta 120þ.
skoða skipti á jeppa á grind eins og pajero, patrol, pathfinder eða svoleiðis má vera orðinn vel morkinn og ryðgaður svo lengi sem að vél sé í þokkalegu standi og hellst dekkjaður allavega til að geta keyrt heim, vill helst beinskipt enn skoða allt!
hafið samband í pm eða í síma 8426433 en ekki eftir 8
Þorvaldur Gunnarsson
Offline Durgur91
Re: snilldar græjupakki til sölu
« Reply #1 on: January 20, 2015, 17:25:04 »
kem suður um helgina, lítið mál að kippa þessu með ef fólk hefur áhuga á að kaupa
Offline Durgur91
« Reply #2 on: January 27, 2015, 00:07:06 »
minni á þetta, skoða öll skemtileg skipti
