Author Topic: Precision Vigilante Multidisc Tourqe converter 3800-4200 stall og Big oil cooler  (Read 7412 times)
Er með einn góöan
Precision Vigilante  Tourqe converter Multi-disc 3800-4200 stall built for nitrous and manual lock up,
 var opnaður , hreinsaður og planaður fyrir 500km í topp standi
passar á ymsa GM bíla , kemur ur 4l65e Vettu 2003
gengur flesta GM bíla 93 og up
þessi þolir hp  :mrgreen:
kostar nýr um $$1050
VERÐ 99.000-
Einnig er ég með stóran B&M oil cooler
Universal Supercooler 20,500BTU mælist í tommum 11 x 8-1/2 x 1-1/2
Description
B&M SuperCoolers are 100% aluminum construction and use stamped plates sandwiched together. This unique design provide for maximized cooling through more efficient heat dissipation but it also provides a much sturdier cooler.
Features and Benefits:
•Small Size and Lightweight
•Better Than Ordinary Cooler
•Rigid Stacked-Plate Design
•Resistant To Damage
•Pressure Tested To 200 PSI
Specifications:
•BTU: 20,500
•Color/Finish: Polished
•Cooler Inlet Size: 1/2 NPT
•Cooling Row Quanity: 40 raðir
•Coolor Outlet Size: 1/2 NPT
•Fittings: 1/2 NPT
Er buið að nota gott sem 500km , fylgja slöngur með þrykktum fittings, beint og í 90° flottur kælir.
Verð 35.000- með öllum slöngum með þrykktum fittings https://bland.is/classified/entry.aspx?classifiedId=2688723
s 8982832
« Last Edit: May 07, 2015, 23:40:03 by bæzi »
TTTT
þetta er alvöru Converter kostar nýr yfir $1000
TILBOÐ óskast
« Last Edit: March 03, 2015, 01:02:07 by bæzi »
Flott setup.....
TIlboð óskast
s 8982832
Converterinn TILBOÐ 99.000-
coolerinn https://bland.is/classified/entry.aspx?classifiedId=2688723
uppl s 8982832
Bæzi
tilboð óskast
