Author Topic: Motorcycle Jacket & Pants BILT EXPLORER H2O Waterproof Adventure NEW!!!  (Read 3522 times)
Offline adam270481
  • Check this out CERAMIZER.COM
Brand new motorcycle jacket and trousers BILT EXPLORER Air Adventure (size L)
BEST USES
Bad Weather
Casual Wear
Long Rides
Safety
•600 denier outer material with airflow mesh inset panels for maximum air cooling
•1200 denier abrasion resistant sections on shoulders and elbows
•3-layer construction: Removable waterproof/breathable/windproof liner, Quilted detachable satin liner, Durable outer shell with air flow inner lining
•Reflective details for increased visibility
•Hydration pack pocket with tube locator on upper back
•Rear pocket with rubber tab pullers
•Multi-point sleeve adjustment tabs for a variable arm fit
•Slide adjustment waist belt for a variable fit
•Mobile phone pouch and additional pockets on inner lining
•Zip entry side hand warmer pockets
•Hook-and-loop hip adjustment
•Short and all-around connection zippers
•CE approved armor at shoulders and elbows
•Memory foam comfort back panel
More information about this item can be found on
http://7acesmotolog.wordpress.com/2013/03/23/bilt-explorer-waterproof-adventure-jacket-first-look/
Verd 95000
