Author Topic: AMMO NYC Bílaşrifavörurnar, Şağ allra besta!  (Read 4179 times)
Offline vesley
« on: August 12, 2013, 09:32:22 »
Tek ağ mér ağ redda AMMO vörum fyrir ykkur sem langar.  Şví meira sem er pantağ í einu şví ódırara gæti şetta orğiğ.
Finnur ekki betri vörur á markağnum.
ATH! şó verğiğ sé kannski ekki ódırt şá er şetta ekki dırt heldur şar sem ég er ağ selja şetta á kostnağarverği.
Takiğ şessi verğ meğ fyrirvara şar sem şau eru einungis viğmiğ! Mun mjög líklega lækka frekar en hækka.
Ammo Paint Regimen Kit. 21.000kr
Kynningar video um şetta kit
http://vimeo.com/40450918#
Ammo Foam Paint Cleanser.
4000kr
AMMO Foam is a safe and unique blend of foaming agents that release dirt from every surface of your paint. This solution offers an unusual degree of sensitivity to the existing layers of protection on your car.
Ammo Skin Defense Coat.
11000kr
AMMO Skin is a defense coat, and is the foundational layer of protection. It is a sticky polymer-based coating that adheres to the clear coat, wrapping the paint in a hard film. It acts like a shell.
Ammo Hydrate Paint Moisturizer.
5000kr
AMMO Hydrate is designed to moisturize this shell. AMMO Hydrate is used after you wash the car to dry and moisturize the paint without scratching it. It strengthens AMMO Skin and leaves behind a layer of protection, fortifying the shell.
Ammo Spit Emergency Shine.  Mögnuğ vara!
3500kr
AMMO Spit is for the dust or light dirt that has been casually accumulating on your car. It is a civilized spray wax for resolutely quick, safe, dimensional, on-the-fly touchups. Draws stares like moths to a light bulb.
Magnağ fyrir şá sem eru ağ taka bílinn á sıningu eğa einfaldlega á rúntinum. Reddar öllu fyrir mann.
Ammo Wheel Regimen Kit
9500kr
The AMMO Wheel Regimen is unique combination of products created to safely keep your wheel, tires, and rims clean and protected. Be sure to use our specialty wheel brushes and techniques to create amazing results.
Şessi pakki inniheldur Ammo Brute. Ammo Plum og Ammo Mud Tire Gel
Kynningar video um kitiğ.
How to Use AMMO Wheel Regimen
Ammo Brute Wheel Soap
3000kr
There’s a difference between car soap and wheel soap. This soap is specifically designed for wheels only. It’s dialed up to give you more strength to clean all the nasty stuff that gets collected on your rims. Use with AMMO Plum Rim Cleaner for unbelievable results.
Ammo Plum Wheel Cleaner.
4000kr
AMMO PLUM WHEEL CLEANER is for those times when your rims need extra help. This is a non-acidic, pH balanced cleaner that sticks to your rim and turns purple as it releases embedded brake dust. Use AMMO Plum Wheel Cleaner and AMMO Brute Wheel Soap together for unbelievable results.
Virkar jafn vel og felgusıra.
Ammo Mud Tire Gel
4000kr
Use AMMO MUD TIRE GEL for a well-balanced shine. It’s water based and extremely sticky…so there’s no tire sling. Penetrating oils moisturize the rubber while protecting its porous surface.
Ammo Interior Regimen Kit.
13000kr  Uppselt eins og er.
The AMMO Interior Regimen is formulated to be gentle on the interior surfaces of your car, while strong enough to clean heavy dirt and grim. Be sure to use our specialty interior brushes and techniques to create unbelievable results.
Cleaning the interior is just as important as protecting your paint. With a regular maintenance, your interior will look, smell, and feel better for every drive.
Şetta kit inniheldur Ammo Lather, Ammo Shag, Ammo Mousse.
Kynningar video um şessar vörur og hvernig á ağ nota şær.
Interior Detailing: Tools, Techniques, and Materials -- /DRIVE CLEAN
Ammo Lather Interior Cleanser.
4500kr
AMMO LATHER INTERIOR CLEANSER is a super-soft cleaner applied with a brush or microfiber towel. Tickle the leather and plastic, gently bringing the dirt to the surface, and wipe away. It’s a delicate method for cleaning and restoring interiors.
Ammo Shag Fabric Cleaner.
4000kr
AMMO SHAG FABRIC CLEANER is specifically formulated for fabric upholstery and carpet cleaning. Simply spray, scrub, then wipe away embedded dirt.
Ammo Mousse Interior Conditioner.
6500kr
AMMO MOUSSE INTERIOR CONDITIONER Once the leather is cleaned (all dirt removed from its pores) it’s time to re-moisturize the hide and fill it up with good stuff.
Ammo Créme Reflective Paste.  Bóniğ fyrir şá rugluğu!
11500kr
AMMO Crème is meticulously hand made, highly reflective carnauba wax that creates paint depth, clarity, and the coveted “wet look.” Use AMMO Crème on top of AMMO Skin for concours reflection and total protection.
Ammo Citrus AP Cleaner.
3500kr
AMMO CITRUS AP CLEANER is a safe all-purpose degreaser. Use on engine compartments to remove heavy grime. Use on rocker panels where they get gummed up. Use on wheels, rims, wheel-wells, doorjambs, and exhaust tips.   Frábært á şessa erfiğu staği.
Microfiber tuskur.
3000kr
Fresh 6-pack of microfiber towels.
Size: 16 by 24 inches
GSM: 300
Scrub Pad.
2700kr
Used to remove tough stains from various interior surfaces such as leather and vinyl.
Tire Gel Applicator Pad.
2500kr
Designed to uniformly apply AMMO Mud Tire Gel to your rubber.
Small Interior Brush. Frábær fyrir leğriğ og alla şrönga og minni staği.
4000kr
Designed for cleaning interior plastic and leather. For use with AMMO Lather Interior Cleanser. Safely agitate dirt to the surface and remove with microfiber towel.
Ammo Shield límmiği.
700kr
Ammo límmiği.
1000kr
