Author Topic: Bosch rafmagnsbensíndæla  (Read 4639 times)
Offline TommiCamaro
« on: July 08, 2013, 23:48:02 »
Bosch 0 580 254 910 Inline Fuel Pump
Bosch 910 fuel pumps mount inline (out side of your gas tank), most commonly rear center under your car or truck. Each Bosch 0-580-254-910 fuel pump provides 130LPH of flow and operate at 72.5 PSI.
Bosch 910 Fuel Pump Specs:
Bosch Part Number: 0580254910
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 34 GPH (130 LPH)
Fuel Pump Location: In-Line
Fuel Pump Connections:
Inlet: 15MM
Outlet: M12 x 1.5
Electrical: Positive M5 / Negative M4
Tómas Einarssson
Offline TommiCamaro
Re: Bosch rafmagnsbensíndæla
« Reply #1 on: January 09, 2014, 10:02:13 »
á til eina svona ennþá
Tómas Einarssson
