Author Topic: 4l60e skipting til sölu. - SELT !  (Read 6493 times)
Offline Hilió
« on: June 28, 2013, 00:21:54 »
Er með 4l60e skiptingu til sölu, keyrð um 200 mílur eftir allsherjar klössun. Kemur úr 2002 Trans Am.
Verð 250 þús.
Sími 895-1215
Hér er það sem fór inn í hana, nótur til fyrir öllu saman, unnið af Einar Gunnlaugs.
750+FWHP w/8"-10" torque converter. Highly modified TransGo Shift kit. BW dual cage 29 element sprag, HD sleeve, extra wide Carbon band, Sonnax 2nd apply servo, Overrun 2-3 Shift Valve, Many upgrades, 10 clutch Borg Warner Hi-Energy 3-4 pack.
This kit has a "highly modified" TransGo Performance Shift kit. Pinless accumulator for Forward & 4th. New "hardened" (RC52) 2nd accumulator pin. Modified 2nd accumulator piston for smoother part throttle 2nd gear shifts. A new pre-drilled TransGo separator plate to match your setup. Includes HD sleeve with modified overrun piston for the input drum and modified steel forward piston, extra wide Alto Carbon 2-4 band & Sonnax 2nd apply servo, Sonnax Overrun 2-3 Shift Valve.
"Complete description of the parts in the rebuild kit"
"Front pump"
Seal retainer
Late design seal
13-vane rotor with 13-vane slide, vanes, rotor guide & pin assembly
TransGo steel rings & priming spring for over 5,500 rpm WOT shifts
New replacement stator support with extra wide bushing installed in the forward part of the stator and a teflon extra wide bushing installed in the rear of the stator
"Clutches, Steels And Pressure Plates"
4 Borg-Warner reverse/input clutches .078
4 Reverse/input "low drag" Turbulator steels .078
1 Reverse/input waved steel (eliminates the oem belleville spring that tears the inside of the drum up)
5 Borg-Warner forward clutches .070
5 Forward steels .091
2 Borg-Warner overrun clutches .078
2 Overrun steels .091
5 Borg-Warner low/reverse clutches .087
5 Low/reverse "low drag" Turbulator steels .068
10 Borg-Warner Hi-Energy 3-4 clutches .065 ("Exclusive")
9 3-4 steels Kolene .060
1 3-4 top pressure plate .098"
1 3-4 bottom pressure plate .106"
1 3-4 snap ring .062"
1 3-4 apply ring with 5 fingers .060"
Sonnax Overrun 2-3 Shift Valve that will hold the overrun clutches on in D3, helps the WOT 2-3 shift in the "D" position
Sonnax Reverse Abuse valve, plug and spring, helps the WOT 2-3 shift
Borg Warner dual cage 29 element design
Beast sunshell
Borg-Warner low/reverse roller clutch assembly (late design)
Vamac 3 lip rear seal
Transtech paper & rubber (gasket) kit
Transmission filter (OEM)
Bushings (latest updates, including Teflon front pump & extension)
Thrust washer kit
Sealing ring kit
HD Bearing kit (Timken)
TransGo Performance Shift kit, with .500 boost valve and PWM eliminator valve
Aluminum 3-4 piston
HD steel sleeve, overrun piston, & "modified" steel forward piston for the input drum
Alto Extra Wide Red or Carbon 2-4 band with re-enforced anchor supports
Sonnax pinless fourth accumulator piston & special seals with matching accumulator spring
Sonnax pinless forward accumulator piston & seals
Modified second accumulator piston, new "hardened" (RC52) pin, & seal with matching accumulator springs (allows for a smooth 1-2 part throttle shift)
Sonnax 2nd Gear "Super Hold" Servo uses cushion springs (18% more apply area than Corvette servo)
Modified steel cover on 2nd apply servo to fix downshift clunks when in the "D" shifter position
New TransGo separator plate with "hardened" corner plate (predrilled to match your setup)
« Last Edit: May 04, 2016, 22:11:07 by Hilió »
Hilmar Ingi
PONTIAC TRANS AM WS6 2002
LS1 346ci 3.90 Gears A4.
1/4 - 11.5@119. 1/8 - 7.35@92 60 ft. - 1.63 N/A (All motor on 98. okt.)
Offline Hilió
Re: 4l60e skipting til sölu.
« Reply #1 on: August 09, 2013, 21:46:33 »
Hilmar Ingi
Offline Hilió
« Reply #2 on: September 06, 2013, 20:55:54 »
Hilmar Ingi
Offline Hilió
« Reply #3 on: April 19, 2014, 03:52:35 »
Þessi er enn til.
Hilmar Ingi
Offline Hilió
« Reply #4 on: March 06, 2015, 23:08:58 »
Þessi er enn til og enn keyrð jafn lítið, mjög skemmtilega upp sett skipting.
Hilmar Ingi
Offline Hilió
Re: 4l60e skipting til sölu. - Lækkað verð.
« Reply #5 on: October 16, 2015, 11:34:40 »
Upp.
Hilmar Ingi
