Author Topic: Auto Meter 6885 "Ultimate II" silver playback tachometer  (Read 2592 times)
Offline jkh
« on: September 28, 2012, 19:49:39 »
Auto Meter 6885 "Ultimate II" silver playback tachometer.
Auto Meter's Ultimate II playback tachometer can record both engine and driveshaft rpm during multiple passes and download both to a laptop computer for onscreen analysis later. With this information you can analyze torque converter/clutch performance, tire shake or slippage, shift points, and much more. It records data at a smooth reading 100 samples per second which means you have .01 second accuracy on the time data.
Auto Meter's easy to use Tach Facts software for downloading, storing, and organizing your run data is included.
5' diameter.
0-11,000 rpm.
Dual channel playback.
Four stage amber LED "Quick-Lite" shift light..
verð 55.000þ
8971289
Jónas Karl
Öll endurbirting á skrifum mínum á þennan vef er með öllu óheimil nema með skriflegu leyfi frá mér.
