Author Topic: Mechanix hanskar og Mechanix Support System  (Read 2804 times)
« on: July 21, 2012, 17:07:28 »
Mechanix Happy Hour hanskar (notağir)
When heat resistance is a must, the hard working Happy Hour Glove delivers. Manufactured with heat and tear resistant Kevlar 18” sleeve, Kodra finger gussets, and a second layer palm patch for high-wear areas; this long-lasting glove gives you full coverage from your fingers to your elbow. The easy slip-on style cuff has been constructed for a super-secure fit.
Mechanix Support System (nırnabelti, ekki meğ plasthlífum, nıtt)
Mechanix Kidney Belt Off-Road Body Armor
Support belt foundation features full coverage elastic rear panels that individually conform to fit lower back
4 separate nylon insert stays provide vertical stability at key areas of contact
Secondary elastic support panels are fully tapered for superior comfort on sides and front
Maximum coverage, hook-and-loop closures feature extra-large nylon pull-tabs for quick, easy adjustment and secure fit
Skjótiğ á mig tilboği
849-2336 eğa bdrt@simnet.is
