Author Topic: TS - Universal Ignition Quick Shifter frá Dynojet  (Read 3383 times)
Offline SMJ
  • Keep smiling and you will end up happy....
« on: May 17, 2012, 22:03:44 »
Er með til sölu Universal Ignition Quick Shifter 4-112 frá Dynojet, hann er nýr í kassanum.
Selst á USA verði eða 325 $ eða 42.000 kall.
- ég tek á mig allan kostnað, sendingarkostnað, vörugjald toll o.fl....
s. 867-1198
Með kveðju,
Sigurjón M. Jóhannsson
Triumph Spitfire Mk3 1968 "MegaBusa"
1986 Ford Sierra Cosworth: 12.434 @ 108.897 MPH
Offline SMJ
Re: TS - Universal Ignition Quick Shifter frá Dynojet
« Reply #1 on: May 30, 2012, 12:08:00 »
Hér eru upplýsingar um tækið:
DYNOJET Universal Quick Shift Ignition Stand Alone Module for ALL 4-Cylinder or less Motorcycles, ATV, and T-REX trikes
This is a stand alone Universal Ignition Quick Shifter module. This unit allows any vehicle with 4 cylinders or less (motorcycle, ATV, mini sprint, etc.) to have quick shifter functionality without the need for a Power Commander. It comes with "coil cap" style connectors for easy installation on most late model motorcycles. For applications that do not have this style of coil the connectors can be removed and the unit hard wired in
User Adjustable "kill times
The Ignition Quick Shifter incorporates a gear position input so that the "kill times" can be adjusted for each gear. "Kill time" can be set shorter in high gears, while also allowing smoother and more positive shifts in lower gears (particularly the 1-2 shift)
Additionally the unit features "intellishift." The controller automatically staggers the "kill times" to cylinder for increased smootheness during lower rpm, part throttle shifts. No computer is required for setup. Installation can be done in as little as 30 minutes. Must be used with one of the 3 DQS shifts sensors (sold separately)
No computer is required for setup. Installation can be done in as little as 30 minutes. Must be used with one of the DQS shift sensor (sold separately). (4-101, 4-110)
FEATURES of Dynojet's Stand Alone Quick Shift Ignition Modules:
User Adjustable
Each Gear can have its own setting
Universal Fit
No Computer Required
Power Commander Not Required
Compatible with PC-III USB style quick shifter sensors
Includes all necessary wires and connectors
Control unit can toggle between road and race settings, depending on usage
Með kveðju,
Offline SMJ
« Reply #2 on: June 25, 2012, 19:23:42 »
Enn til sölu.
Með kveðju,
