Author Topic: Ýmislegt  (Read 3194 times)
Offline jkh
Ýmislegt
« on: June 13, 2011, 20:19:47 »
Til sölu Gerið tilboð ekki spyrja um verð . 8971289
Auto meter hraðamælir á ónotaður
Auto meter snúningsmælir
4.10 dana hlutfall
brons drive kveikju drif
Nítró plata lítil
24 volta start
Auto Meter 6885 "Ultimate II" silver playback tachometer.
Auto Meter's Ultimate II playback tachometer can record both engine and driveshaft rpm during multiple passes and download both to a laptop computer for onscreen analysis later. With this information you can analyze torque converter/clutch performance, tire shake or slippage, shift points, and much more. It records data at a smooth reading 100 samples per second which means you have .01 second accuracy on the time data.
Auto Meter's easy to use Tach Facts software for downloading, storing, and organizing your run data is included.
5' diameter.
0-11,000 rpm.
Dual channel playback.
Four stage amber LED "Quick-Lite" shift light.
Includes "Tach Facts" software.
Jónas Karl
Öll endurbirting á skrifum mínum á þennan vef er með öllu óheimil nema með skriflegu leyfi frá mér.
