Author Topic: Walbro 255 lph High Pressure Fuel pump  (Read 2348 times)
« on: February 21, 2011, 07:57:02 »
Walbro Fuel Pump Universal gss342
The Walbro high output in-tank electric fuel pumps are available in flow ratings of 255 liters of fuel per hour. These particular pumps flow significantly more fuel at higher pressure. For example, at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour.
Walbro in-tank electric fuel pumps utilize a proven gerotor design. The outside dimensions, however, are compact enough to fit existing hanger assemblies, without modification. Coverage includes most popular Acura and Honda, Ford, Chrysler and many other Import applications.
These are complete fuel pump kits and include all drop parts, accessories and installation instructions. Also included is an inlet filter that meets or exceeds original equipment specifications and provides improved filtration and durability.
passar í Acura Integra 94-00, Eagle Talon 95-99, Ford Mustang Cobra 96-97, probe Gt 93-97, Honda Accord 94-97 , Honda Civic 92-00 , Mazda Miata 94-97 , Mazda Mx6 92-97 , MMC Eclipse 95-99 og evo 03-06 , Nissan 200sx 95-98 og 200sx se-R 95-98 , Nissan Sentra og Sentra Se 98-99, Nissan Sentra Se-R 91-94 , Subaru wrx og sti öll ár , Toyota Supra 93-98.
Fæst á óprúttanlegu verði sem er 20 þús kr með install kit fyrir Imprezu Wrx 2.0L 2005 þó það á nú að passa í allar imprezur
Auðvita nýtt og enn í upprunnalegum óopnuðum pakkningum
Davíð
8440345
