Author Topic: meira afl í 318 magnum...  (Read 3782 times)
Offline spámaður
« on: February 01, 2011, 14:52:30 »
sælir.félagi minn er að missa svefn yfir því að hafa ekki nóg afl í jeppanum sínum,hann vill fá meira afl út úr kæfunni.
hvað breytingar eru í boði fyrir þessa vél td 50 auka hö eða meira.vill ekki nitro,þetta er bone stock 318 magnum úr ram.
kv kraftlauswyllisemkemstekkertáfram :mrgreen:
Hlynur þór birgisson
toyota hilux 39.5" TD´90
ford f250 5.4 D '74
bronco/wyllis 351w´66 eilifðarverkefni.
toyota landcruiser 60 D '85
KTM EXC 450´07
Ford thunderbird supercharger3.8´94
toyota carina e2.0´93
The last one to die is a pussy
Offline co-caine
Re: meira afl í 318 magnum...
« Reply #1 on: February 01, 2011, 18:56:56 »
Larger throttle body http://www.thefastman.com/Throttlebodies47.asp, Kegger mod http://dodgeforum.com/forum/2nd-gen-...e-mod-diy.html,
1.7:1 Lifters (I would suggest. http://store.summitracing.com/partde...7&autoview=sku
Much cheaper then the Mopar or Crower kits, and much easier to install in my opinion (no lash adjustments, no guide plates, fits under stock valve cover) http://www.pavementsucks.com/tech/rollerrocker.php http://dodgeforum.com/forum/2nd-gen-...r-install.html)
Cams
Mopar Performance computer
High output coil + wires + cap and rotor
Spark plugs (Autolite 3923's)
Higher flow injectors
Headers
Open flowing exhaust systems
High flow cat
Lower (numerically higher) Rear End Gears
Transmission shift kit
Machine work (deck down block, heads) (Bore out cylinders).
Polish and port heads and headers
Electric cooling fan
Electric coolant pump http://www.csr-performance.com/csr_pumps.html
Under Drive pulley's. (be careful lots are 6 ribs. Magnums use 7 ribs)
Lots more....
http://www.hughesengines.com/TechArt...es03012004.php (V6 Performance
400HP on 318 http://web.archive.org/web/200605141...318/index.html
http://www.popularhotrodding.com/tec...ecs/index.html
http://www.popularhotrodding.com/eng...ads/index.html
Páll I Pálsson
Offline spámaður
« Reply #2 on: February 01, 2011, 20:08:19 »
þakka þér fyrir góð og skjót svör co-caine :D nú verður farið vel og vandlega yfir þetta og vonandi brotnir ehv öxlar og drif í kjölfarið. #-o
ford f250 5.4 D '74
KTM EXC 450´07
