Author Topic: 1991 Firebird Formula "Storm Trooper" LS7 427  (Read 6549 times)
Offline 348ci SS
« on: November 15, 2010, 08:43:37 »
We introduce to you our 1991 Firebird Formula AKA "Storm Trooper". After several months of R & D work, we finished our Magnacharged LS7 427 powered 1991 Firebird Formula.
1991 Firebird Formula, White with Gray Interior
Engine is LS7 427cid with a Level II T56 Transmission
11.0:1 Compression Ratio
Stock LS7 Aluminum, 2.20 Intake and 1.61 Exhaust Valves
Custom  Grind Camshaft
Stock Hypereutectic Pistons
Stock Forged Steel Crankshaft
Stock Forged Titanium Rods
Custom Carbon Fiber Cold Air Intake
Stock 90mm Throttle Body
Fuel System 60lb Injectors & Racetronix Fuel Pump 255lph
Stock Coils, MSD Wires, TR7 Plugs
Hawks 2" LT Headers, 3" Y-Pipe, 3.5" Catback
Magnuson TVS 2300
ATI 8-Rib Pulley
Magnuson Intercooler
E38 ECM
Pro 5.0 Shifter
Ram Dual Disc Clutch
3.5" Aluminum Driveshaft
Moser 12 Bolt, 33 spline axles, 3.73 gear & Auburn Posi
KYB Shocks, Hotchkis Springs, 36mm Sway Bar Front Suspension
BMR LCAs, KYB Shocks, Hotchkis Springs, BMR Trak Pak Torque Arm, BMR Panhard Bar, 24mm Sway Bar Rear Suspension
Boze Mesh 18x9.5 Fronts & 18x10.5 Rear Wheels
Nitto 555 275/35/18 Fronts, Nitto 555R Drag Radial 305/35/18 Rear Tires
C6 Z06 Rotor, C5 Z06 Caliper Front Brakes & Custom Wilwood Rear Brakes
Custom fabricated "ZR1" style hood with clear polycarbonate insert
meira myndir hér.
http://www.hawksthirdgenparts.com/stormtrooper.aspx
Hallbjörn Freyr.
Ford Crown Victoria glasstop 56' Nr. 601 af 603 framleiddum
Chevrolet 3rd Gen Camaro z28 84' gera upp frá A-Ö
Re: 1991 Firebird Formula "Storm Trooper" LS7 427
« Reply #1 on: November 15, 2010, 09:26:18 »
nice
« Reply #2 on: November 15, 2010, 17:22:36 »
Mjög smekklegt 8-)
Offline Gummari
  • UNICORN
« Reply #3 on: November 15, 2010, 22:03:13 »
flottur alltaf soldið skotinn í þessum nebba  :)
69 Mustang Mach1
70 Pontiac Firebird
77 VW Bjalla chop top
Toyota Auris Ökukennslubíll hjá frúnni
ÖKULIND s.8979969 tilboð fyrir KK
