Author Topic: Camaro 67' 1200hp  (Read 8381 times)
Offline 348ci SS
Camaro 67' 1200hp
« on: August 23, 2010, 21:22:37 »
Type: Chevy 385 small-block
Block: Dart Little M, bored to 4.040 inches
Oiling: Melling oil pump, Milodon pan
Rotating assembly: Lunati 3.750-inch forged crank and billet steel rods,forged 8.5:1 Arias pistons
Cylinder heads: ported RHS 220cc aluminum castings with 2.08/1.60-inch Manley valves and 64cc chambers
Camshaft: COMP Cams 262/272-at-0.050 solid roller, 0.672/0.672-inch lift, 114-degree LSA
Valvetrain: Jesel 1.7:1 shaft-mount rockers and beltdrive; Manley springs,titanium retainers, and pushrods
Induction: World Products Motown intake manifold, C&S 4150-style 800cfm carb,Extreme Velocity blow-through carb hat
Exhaust: custom 1¾-inch turbo headers,
  downpipes, and dual 3-inch Spin Tech mufflers
Power adder: twin Turbonetics T-76 turbochargers and wastegates; dual TiAL blow-off valves and custom air-to-air intercoolers Fuel
system: Aeromotive pump, filters, and regulator
Ignition: MSD Digital 7 box, billet distributor, HVC 2 coil and plug wires
Cooling: Be Cool radiator, CSR electric pump, Derale fan
Output: 1,174 hp at 7,200 rpm and 998 lb-ft at 4,000 rpm
Built by: Lonny Patrick
DRIVETRAIN
Transmission: GM TH400 auto with trans brake,
  Neil Chance 3,400-stall converter,
  PPP air shifter
Rear axle: Chassisworks fabricated 9-inch
  rearend housing with 35-spline axles,
  spool and 4.10:1 gears
CHASSIS
Front suspension: TR2 tubular control arms,
  QA1 coilovers, CPP drop spindles
Rear suspension: Calvert Racing leaf springs
  and traction bars; QA1 shocks
Brakes: Aerospace Engineering
  four-piston discs front and rear
WHEELS & TIRES
Wheels: Billet Specialties Street Lite
  15x4, front; 15x10, rear
Tires: Mickey Thompson
  28x7.5x15 Sportsman, front;
  315/60R15 ET Street Radials, rear
http://www.google.is/imgres?imgurl=http://image.popularhotrodding.com/f/features/0910phr_1967_chevy_camaro/26782978%2Bpheader_460x1000/0910phr_01_z%2B1967_chevy_camaro%2Bcowl_hood.jpg&imgrefurl=http://www.popularhotrodding.com/features/0910phr_1967_chevy_camaro/pistons.html&usg=__zY8eF7AnPGATAjpUlCy1hawAv-c=&h=345&w=460&sz=46&hl=is&start=576&zoom=1&itbs=1&tbnid=HGPzYIsCL9tK2M:&tbnh=96&tbnw=128&prev=/images%3Fq%3Dtire%2Bshake%2BCamaro%26start%3D558%26hl%3Dis%26sa%3DN%26gbv%3D2%26ndsp%3D18%26tbs%3Disch:1
« Last Edit: August 23, 2010, 21:25:12 by hallbjorn freyr 'Omarsson »
Hallbjörn Freyr.
Ford Crown Victoria glasstop 56' Nr. 601 af 603 framleiddum
Chevrolet 3rd Gen Camaro z28 84' gera upp frį A-Ö
  • Frišrik Danķelss.
Re: Camaro 67' 1200hp
« Reply #1 on: August 23, 2010, 22:44:57 »
Geggjašur  :shock:
Offline 348ci SS
« Reply #2 on: August 24, 2010, 01:47:19 »
Hallbjörn Freyr.
Offline Svenni Devil Racing
« Reply #3 on: August 26, 2010, 19:17:42 »
wooowww  :shock: bara flottur
DEVIL RACING
camaro įrg 82 berlinette
camaro įrg 83 z-28
camaro įrg 85 iroc-z
camaro įrg 94 z-28
camaro įrg 95 z-28
og fullt af öšru GM Dóti
Sveinn Heišar Frišriksson
og fullt af öršum chevy gęša dóti
