Author Topic: Launch CReader 5 V EOBD OBD2 CANBUS Fault Code Reader  (Read 2988 times)
Offline batt
« on: March 27, 2010, 11:07:08 »
CReader V var nýlega framleitt af LAUNCH, sérhannað með bíleigendur eða áhuga viðgerðarmenn í huga til þess að greina hvaða bíl sem er með OBD II/EOBD. Það les/eyðir ekki einungis DTC kóða heldur er einnig kleift að lesa “live data” á tveimur stillingum og framkvæma margar mismunandi prófanir.
You will need this when seeing "Check Engine" light on!
Operation Language : English
Supported Protocols :
OBDII: ISO9141
SAE J1850VPW
SAE J1850 PWM
EOBD: ISO14230 KPW
CANBUS: ISO15765
Features:
1. Read Codes
2. Erase Codes
3. View Freeze Data
4. Data Stream
 - Entire Data List
 -Custom Data List
5. Special Tests
 -I/M Readiness
 -MIL Status
 -O2 Sensor Test
 -On-board monitor Test
 -EVAP System Test
 -Vehicle Info
6. Code Lookup
7. Free Internet Updates
Specifications:
Display: Backlit, 160 x 160 pixels
Operating Temperature: 0 to 60°C (32 to 140 F°)
Storage Temperature: -20 to 70°C (-4 to 158 F°)
Power: 8 to 18 Volts provided via DLC
Unit Dimensions (Length×Width×Thickness): 126 mm×88 mm×22 mm
Test Cable length: 0.9m
Accessories:
User’s Manual -- Instructions on tool operations
USB cable--Connect to a computer for upgrading online
Verð 29.000 kr.
Nánari uppl. 8633749
Offline batt
Re: Launch CReader 5 V EOBD OBD2 CANBUS Fault Code Reader
« Reply #1 on: April 03, 2010, 21:36:02 »
Skoða skipti á GPS
Offline batt
« Reply #2 on: April 22, 2010, 19:53:45 »
seldur
« Last Edit: June 25, 2010, 22:55:17 by batt »
