Author Topic: Til sölu Dynatek ARC-2 CDI Kveikjumagnari  (Read 2585 times)
Offline Lolli DSM
« on: March 11, 2010, 23:09:58 »
Ég er ağ selja şennan kveikjumagnara şví mig vantar 4 channel magnara.
Hann er alveg ónotağur og er í kassanum og fylgir universal harness plug meğ honum.
Verğ 50.000kr
Hægt ağ nota sem launch control og og kveikju seinkara.
http://www.dynaonline.com/skins/products/automotive/arc_2/
ARC-2 Features
    * Smallest Ligthest CDI on the market
    * Over 189mJ delivered to the coil per spark, the highest of any other on the market
    * Over 500V to the coil primary
    * Over 50kV to the coil secondary (assuming a 100:1 coil)
    * Intelligent Spark Profiling (ISP) allows for less delay Suzuki between successive sparks
    * Spark Restrike up to 4500 RPM
    * Provides this high level of output from as low as 8 Volts from the battery
    * Works with any 2 coil OEM ignition, with or without fac ignitor (some systems may require replacement coils)
    * Built in launch limiter, works from 2000-11900 RPM
    * Built in fixed timing retard function
    * Tach output
ARC-2 Technical Specifications
Operating Voltage:
8-20 Volts
Operating Current:
7.0A @ 10, 000 RPM
Maximum Operational RPM:
18, 000+ RPM
Ignition Inputs:
2 Rising or Falling Edge
Ignition Outputs:
2 Independent Channels
Coil Primary Energy Max:
189+ mJ
Coil Primary Voltage Max:
500+ V
Restrike Window:
25 Cranksahft Degrees
Launch Limiter Input:
Single wire, ground to activate launch limit
Retard Input:
Single wire, ground to activate timing retard
Tach Output:
12V square wave, 50% duty cycle
Dimensions:
4" x 4.6" x 1.4"
Weight:
<1.25 lb.
Verğ 50.000kr
Şórğur Birgisson a.k.a. Lolli
Mitsubishi Eclipse GSX 1990
9.65@148mph Best trap 150mph! Ethanol + Avgas blanda 50%
10.65@129.6 á 100oct dælubensín
Offline Lolli DSM
Re: Til sölu Dynatek ARC-2 CDI Kveikjumagnari
« Reply #1 on: March 15, 2010, 14:15:46 »
Til sölu!!
