Author Topic: Ó.E. 4.56 hlutföllum í D44 scout eða GM 12bolta 30 rillu  (Read 1850 times)
Offline ElliOfur
    • http://www.123.is/elliofur/
Mig vantar 4.56 hlutföll í 12bolta gm afturhásingu, 8.875" nú eða D44 8.5", mér er alveg sama í hvort það er, ég sker þessar hásingar bara í sundur og sýð saman eftir þörfum.
D44 specs;
10 bolt cover with 8.5" ring gear. Found in both front and rear applications. Rear applications use a bolt in axle. Axles are 30 spline. Front applications came in both standard and reverse rotation.
Ring Gear Diameter: 8.5
Ring Gear Bolts: (10) 3/8 x 24 RH
Cover Bolts: 10
Spline Count: 30
Float: SF or Front
Pinion Support: False
Compatible with Models:
1/2 Ton Dodge Pickup: 1955 - 2002 (Front)
1/2 Ton GM Pickup: 1960 - 1980 (Front)
1/2 Ton GM Pickup: 1967 - 1972 (Rear)
3/4 Ton Dodge Pickup: 1955 - 2002 (Front)
3/4 Ton GM Pickup: 1960 - 1980 (Front)
420: 1958 - 1970 (Rear)
Blazer: 1969 - 1979 (Front)
Bronco: 1971 - 1977 (Front)
CJ5: 1966 - 1975 (Rear)
CJ5: 1971 - 1983 (Front)
CJ6: 1966 - 1975 (Rear)
CJ6: 1971 - 1983 (Front)
CJ7: 1976 - 1986 (Front)
CJ7: 1986 - 1986 (Rear)
CJ8: 1981 - 1986 (Front)
CJ8: 1981 - 1986 (Rear)
Commando: 1966 - 1973 (Rear)
F100: 1948 - 1979 (Rear)
F150: 1967 - 1996 (Front)
F250: 1959 - 1989 (Front)
F350: 1979 - 1979 (Front)
Grand Wagoneer: 1984 - 1991 (Front)
Grand Wagoneer: 1984 - 1991 (Rear)
J10: 1972 - 1983 (Rear)
Mark I: 1950 - 1970 (Rear)
Mark II: 1950 - 1970 (Rear)
Mark X: 1958 - 1970 (Rear)
Ram Charger: 1974 - 1993 (Front)
Rodeo: 1993 - 1997 (Rear)
Scout 800: 1967 - 1971 (Rear)
Scout II: 1972 - 1980 (Front)
Scout II: 1972 - 1980 (Rear)
Suburban 1/2 Ton: 1969 - 1979 (Front)
TJ: 1997 - 2004 (Rear)
TJ: 2003 - 2005 (Front)
Wagoneer: 1971 - 1992 (Rear)
Wagoneer: 1974 - 1992 (Front)
XJ: 1986 - 1989 (Rear)
XJ Sport: 1986 - 1989 (Rear)
XJR: 1940 - 1940 (Front)
XJS: 1976 - 1997 (Rear)
XK8: 1961 - 1974 (Rear)
X-Type: 1974 - 1995 (Rear)
GM12T specs
12 bolt rear cover with 8.875" ring gear using 12 ring gear bolts. Has 30 spline c/clip
Ring Gear Diameter:
Ring Gear Bolts: (12) 3/8 x 24 RH
Cover Bolts: 12
Spline Count: 30
Float: SF
1/2 Ton GM Pickup: 1963 - 1981 (Rear)
1/2 Ton GM Van: 1963 - 1981 (Rear)
Blazer: 1969 - 1981 (Rear)
Suburban 1/2 Ton: 1969 - 1981 (Rear)
Ég á í aðra hásinguna og vantar því bara einn kamb og einn pinjón
Svo væri flott að fá læsingu líka, helst no-spin en ég skoða allt sem mér býðst.
elliofur@vesturland.is eða 8666443
kveðja, Elmar Snorrason
_________________
http://www.123.is/elliofur/ - heilmikið bílagrúsk
