Author Topic: vantar upplisingar um suzuki intruter  (Read 4953 times)
Offline z2894
« on: March 07, 2010, 00:23:30 »
góđan daginn er međ suzuki intruter 800 2001 árg mér vantar ađ vita herslutölur á mótor getur eithver sagt mér hvar ég finn ţetta eđa veit ţetta kanski eithver endilega láta mig vita í síma 8699644 nú eđa bara hér á spjallinu.
já og hvar er best ađ versla varahluti í ţetta hjól á sem hagstćđastan hátt
Ásgeir ólafsson
Offline Gulag
    • AMJ.is - Bremsuslöngur í mótorhjól
Re: vantar upplisingar um suzuki intruter
« Reply #1 on: March 09, 2010, 17:03:07 »
Camshaft sprocket bolts 14-16 Nm
Cylinder head cover bolts Bolt length 140 mm & 243 mm 21-25Nm All other lengths 9-11Nm
Rocker arm shafts 25-30 Nm
Cylinder head-to-cylinder nuts 8-12 Nm
Cylinder head-to-cylinder bolts 9-11 Nm
Cylinder head and cylinder bolts 35-40 Nm
Oil pump mounting bolts 7-9 Nm
drive gear bolt 80-110 Nm
Secondary gear bevel gear assembly Allen bolts 18-28 Nm
Case bolts Initial 12-18 Nm / Final 20-24 Nm
Secondary gear housing bolts 18-28 Nm
Secondary drive gear nut 80-110 Nm
Transmission main shaft bolt 60-70 Nm
Crankcase bolts Initial 6 mm —8mm 12-18 Nm / Final 6mm 9-13 Nm - 8mm 20-24 Nm
Camshaft chain tensioner guide bolt 8-12 Nm
Connecting rod cap nuts Initial 22-28 Nm / Final 51-55 Nm
Atli Már Jóhannsson
Offline z2894
« Reply #2 on: March 09, 2010, 20:53:24 »
snild takk fyrir ţetta en hvar finnurđu eigilega ţessar uppl.
Ásgeir ólafsson
Offline Gulag
« Reply #3 on: March 09, 2010, 21:50:09 »
bara í bókinni..  :D
svo eru hellingur af viđgerđarbókum hér:
http://www.ruddar.com/Xodus.aspx?id=165&MainCatID=44
Atli Már Jóhannsson
