Author Topic: TIG suğa til sölu  (Read 4293 times)
Offline bergur01
    • http://www.netberg.is
TIG suğa til sölu
« on: February 01, 2010, 12:33:44 »
Weco 150E Tig Welder
WECO Discovery 150E Tig Welder
Welding Current 5 - 150A
Duty Cycle 35% @140A
O.C.V 54V
Main Power Supply 230v (+,-) 15%
Main Fuse 16A
Protection IP23
Insulation B
Norms EN60974 - 1/ EN 50199
Dimensions 12 x 31 x 21.5cm
Weight 4.3kg
Functions Hot start, anti stick
Features Complete with arc welding and earth leads .
MMA/ Arc Welding
* HOT START: Managed by the microprocessor in WECO inverters according to the welding current, hot start consists of a rise in the initial current to allow for better striking of the electrode.
* ARC FORCE: Regulated by the microprocessor according to the welding current, arc force entails a rise in current to facilitate detachment of droplet transfer.
* ANTI STICK: The WECO anti stick function causes the welding current to be blocking in the event that the electrode should stick to the piece.
TIG
* LIFT ARC: All “E” Series inverters use touch- and- lift tungsten start.
* PULSE: Pulse allows the current to be pulsed between values of amps selected, mitigated by determined or selected frequency (Hz). WECO inverters have pulse available in all models of TIG inverters.
* In the “E” Series the pulse has the frequency and current settings factory set according to the welding current.
Kostar $1.395 (177.000 kr) úti og şá á eftir ağ flytja hana heim.
Aldrei veriğ notuğ. Fæst á 100.000 kr
Bergur
615-1251
bergur@opex.is
