Author Topic: Comp Cams hyd. roller + lyftur SBC til sölu SELT  (Read 2283 times)
Offline Kristó.
« on: November 22, 2009, 20:53:32 »
Til sölu flottur street strip CompCams Hyd. roller  kambás, lyftur og gormar.SBC Notað 1 sumar.
Verð 50 þús.
Uppl í síma 693 5490 eða pm
Kristó.
Features:
Advertised Duration    280 int./280 exh.
Advertised Exhaust Duration    280
Advertised Intake Duration    280
Assembly Lubricant Included    Yes
Basic Operating RPM Range    2,500-6,000
Cam Style    Hydraulic roller tappet
Computer-Controlled Compatible    No
Duration at 050 inch Lift    224 int./224 exh.
Exhaust Duration at 050 inch Lift    224
Exhaust Valve Lash    0.000 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio    0.560 in.
Gaskets Included    No
Grind Number    FW 280H-R10
Intake Duration at 050 inch Lift    224
Intake Valve Lash    0.000 in.
Intake Valve Lift with Factory Rocker Arm Ratio    0.560 in.
Lifter Style    Hydraulic roller
Lifters Included    Yes
Lobe Separation (degrees)    110
« Last Edit: November 22, 2009, 22:51:09 by Kristó. »
