Author Topic: Triumph Trophy 900cc  (Read 2467 times)
Offline jkh
« on: November 02, 2009, 19:05:44 »
Triumph Trophy 900cc árg 2000 ekið um 22.000 m
tilboð óskast
  885.00 ccm (54.00 cubic inches) Engine type: In-line three Stroke: 4 Power: 98.00 HP (71.5 kW)) @ 9000 RPM Torque: 83.00 Nm (8.5 kgf-m or 61.2 ft.lbs) @ 6500 RPM Valves per cylinder: 4 Starter: Electric Cooling system: Liquid Gearbox: 6-speed Physical measures Dry weight: 220.0 kg (485.0 pounds) Seat height: 790 mm (31.1 inches) If adjustable, lowest setting. Chassis and dimensions Front brakes: Dual disc Rear brakes: Single disc Speed and acceleration Power/weight ratio: 0.4455 HP/kg
uppl 8971289
« Last Edit: November 02, 2009, 19:20:47 by jkh »
Jónas Karl
Öll endurbirting á skrifum mínum á þennan vef er með öllu óheimil nema með skriflegu leyfi frá mér.
