Author Topic: Stór bassapakki í bíl 5000w á 75þús s:846-5436  (Read 2763 times)
Offline dofri
« on: October 01, 2009, 17:26:21 »
Pakkinn samanstendur af:
2x10" Pioneer Champion Series PRO (2500w hvor) í portuðu boxi
Description:    Champion Series PRO TS-W2501D2 10" Car Subwoofer (Dual Coil, 800 Watts, 4 Ohms, 87 dB, Sealed Enclosure)
Manufacturer:    Pioneer
Power & Sound
Peak Power    2500 W
RMS Power    800 W
Sensitivity    115 db
Nominal Impedance    4 ohm(s)
Overall Min Frequency Response    18 Hz
Overall Max Frequency Response    1000 Hz
Material
Diameter    10 in
Cone Style    Cone
Voice Coil    Dual
Speaker Enclosure Type    Sealed
General
Integrated Features    Amplifier
Mounting Depth    6.66 in
Warranty Information    1 Year Limited Warranty
Soundstream Tarantula 1400.2 magnari
    *  Number of Channels: 2
    * RMS @ 4 Ohms: 350 watts x 2 chan.
    * RMS @ 2 Ohms: 700 watts x 2 chan.
    * RMS Bridged @ 4 Ohms: 1400 watts x 1 chan.
    * T.H.D.: < 0.02%
    * Frequency Response: 10 Hz - 50 kHz
    * S/N Ratio: >115dB
    * Damping Factor: >500
    * Input Sensitivity: 0.15 - 12.0 V
    * Crossover Slope: 12dB
    * Crossover Frequency: 50 Hz - 5 kHz
    * Dimensions: 10.75" x 2.6" x 24.25"
    * Variable high pass, band pass, low pass
    * Variable 18dB bass boost
    * Double sided glass epoxy SMT circuit board
    * PWM mosfet power supply
    * Tri-guard amplifier protection
    * SMT cooling fan built in
    * Tri-mode capable
    * Line output
    * 1-year SonicElectronix.com warranty
Þéttir frá Bluewave 1.3 farad
[SIZE="5"]Þetta fer allt á mjög sanngjörnu verði, eða 75.000kr í peningum[/SIZE]
PS: Allt var þetta verslað á þessu ári nema þéttirinn sem var keyptur í október í fyrra
« Last Edit: October 01, 2009, 17:55:18 by dofri »
Kjartan Dofri
Nissan Silvia s14 12.586@108.43mph / 60ft: 1.726
