Author Topic: Honda Hornet 2007  (Read 3090 times)
Offline Kiddi J
  • NTGLTY
Honda Hornet 2007
« on: June 14, 2009, 22:12:37 »
Til sölu : Honda CB 600F Hornet 2007
Specs: (tekið af http://www.motorcyclespecs.co.za/model/Honda/honda_cb600_hornet%2007.htm )
Engine
 Liquid cooled, four stroke, transverse four cylinder, DOHC, 4 valves per cylinder.
Capacity
 599
Bore x Stroke 67 x 42,5 mm
Compression Ratio 12.0:1
Induction
 PGM-FI electronic fuel injection. 36mm Throttle Bore
Ignition  /  Starting
 Computer-controlled digital transistorised with electronic advance  /  electric
Max Power
 102 hp 75 kW @ 12000 rpm
Max Torque
 6.5 m-kg 63.5 Nm @ 10500 rpm
Gear Ratio 1st 2.750 (33/12) / 2nd 1.938 (31/16) /3rd 1.556 (28/18) / 4th 1.348 (31/23) 5th 1.208 (29/24) /6th 1.095 (23/21)
Transmission  /  Drive
 6 Speed  /  chain
Frame Mono-backbone; rectangular-section gravity die-cast aluminium
Front Suspension
 41mm inverted telescopic fork, 120mm wheell travel
Rear Suspension
 Monoshock damper with 7-step adjustable preload, 128mm wheel travel
Front Brakes
 2x 296mm discs 2 piston caliper
Rear Brakes
 Single 250mm disc 1 piston calipers
Front Tyre
 120/70ZR17
Rear Tyre
 180/55ZR17
Seat Height 800 mm
Dry-Weight
 173 kg / 177 kg ABS
Fuel Capacity
 19 Litres
Consumption  average
 19.6  km/lit
Standing ¼ Mile
 11.6 sec  /  189.3 km/h
Standing 1000m 22.2 sec  /  214.1 km/h
Top Speed
 223.9  km/h
Hjólið er ekið 50XX km.
Áhvílandi lán er í krignum 1300 þús kr., fæst á yfirtöku ásamt reiðufé. Lánið er í frystinum og er afborgun um 20 þús kr.
PM eða 867-1033
Kristinn Jónasson
Offline Kiddi J
  • NTGLTY
Re: Honda Hornet 2007
« Reply #1 on: June 29, 2009, 19:44:53 »
 8-) 8-) 8-)
Kristinn Jónasson
