Author Topic: 2st PIAA 90 Pro Lamps til sölu  (Read 2394 times)
Offline riva
« on: February 10, 2009, 20:00:17 »
sími 848-3200 bjóssi
Changing weather conditions affect us all.  Now you can adapt at the flick of a switch.  Both fog and driving lamps are contained in a single unit.   Completly separate bulbs and reflectors make this the perfect space-saving kit for tight installations.  The projector fog has a 100 watt equivalent lamp that uses only 55w.  The driving H3 lamp is an 85 watt bulb that illuminates with the equivalent of a 130 watt lamp. Kit includes two lights, wiring harness, switch and relay. Dimensions: 9 1/4"L x 3 3/4"H x 5 1/2"D
Available In: Clear projector Fog with Clear Driving or Ion Crystal projector fog with clear driving
Bulb Type: 12V-H1 55Watt=100Watt XTRA fog and 12V-H3 85Watt=130Watt XTRA driving
Features: Dual lamp system, black aluminum housing, glass lens
Kit Includes: Two lamps, wiring harness, relay, switch, and two white lamp covers with black lettering
lettering
