Author Topic: til sölu 572 all aluminum blown alcky,,,,selt/komiğ í notkun.  (Read 3326 times)
Offline Raggi
572 BBC for sale,,its an all aluminum motor,,new dart big m aluminum tall deck block with billet splayed caps,,new callies magnum crank,,used aries pistons 12:1 comp,,used scs billet aluminum rods(around  6,640" long),,new fab moroso aluminum pan,,new moroso billet aluminum oil pump,,new comp cam 284/296°@050,748 lift 112°lobe separation, 4/7 swap,,new isky red zone roler lifters,,used bmf 385 cnc heds,used two summers, no mods exept for one thread repair in rockerstud hole (http://www.thebmfstore.com/ProductDetails.asp?ProductCode=10385) flow 432 cfm @.800lift,,used fluiddamper,,used msd crank trigger, machined for use with blower drive,,litlefeild blower pulley adapter with one acessory belt slot,,dual idler 13,9" blower drive system with 4 asorted pulleys range'n from 35% underdrive to 29% owerdrive,,14:71 litlefeild high helix blower, used,some scratces on rotors,,enderlay Buzzardcatcher mecanical alchohol injection used and does not inclde jets,some plumming and some small parts,,
msd probillet distribiutor, low profile fits under rear of blower,,nib msd 7digital ingnitionbox,,litlefeild talldeck blower manifold,,comp cam high tech push rods,,harland sharp 1,8 ratio rockers and so on,,manifold, blower and ics titan headgaskets included motor stands as shown on picture to day,,more pics awaylable upon request,,also have Neil chance bolt to gether converter for above motor,,
ran out of greens to finish project,,motor was made with blown alky in mynd but will yust as easily run on gas with ading manifold and carb
coperaği bara auglísinguna sem fór á Nitroz.se í dag,,myndir og frekara infó fáanlegt á email (ragnarsteinthors@simnet.is) eğa í síma 864 3098 8-)
Sakar ekkert ağ bjóğa eitthvağ,,óşarfi ağ selja şetta úr landi á 1,5mil til şess eins ağ fara ağ flytja şetta aftur inn fyrir 3mil :roll: :mrgreen:
« Last Edit: February 03, 2009, 09:48:04 by Raggi »
There is no replasement for more displasement
