Author Topic: B&M Converter  (Read 3870 times)
Offline Bílabúð Benna
    • Bílabúð Benna
B&M Converter
« on: December 17, 2008, 12:28:38 »
#20402
Tork Master 3000
Application
Tork Master 3000 for GM ’65-’91 TH400, 425, 375 ’68-’81 & TH350, 375B (not 350C)
The Tork Master is B&M's lowest cost performance torque converter. The Tork Master is an excellent all-around performance street converter. The best 'value priced' street converters available, Tork Master converters come with a new precision pump drive tube and all are pressure tested and fully balanced. The Tork Master torque converter is not recommended for big block or supercharged applications.
* New allow steel pump drive tube
* Needle thrust bearing when factory equipped
* New thrust washer between turbine and cover when required
Application
Tilboðsverð 49,146.kr
Vagnhöfða 23.  S: 590-2000.
