Author Topic: MOROSO Accumulator  (Read 3984 times)
Offline Bílabúð Benna
    • Bílabúð Benna
MOROSO Accumulator
« on: December 16, 2008, 15:36:52 »
#23900
Accumulator, 3 quart capacity, 20-1/8" x 4-1/4"
The Accumulator is tapped to the pressure side of the engine’s oiling system. When the engine is running, oil pressure forces reserve oil into the accumulator and compresses the air ahead.
If oil pressure should suddenly drop because of hard acceleration, severe cornering or hard braking, the air pressure immediately sends oil to the main galleries. When the danger is over and the pump is once again primed with oil, the oil pressure forces oil back into the Accumulator where it is ready for the next emergency.
Moroso Oil Accumulators provide an instantaneous supply of oil when pressure falls below a safe level. Our professional series Accumulator, designed for all-out competition, is now available with a 3- or 1.5-quart capacity. The 1.5-quart version is perfect for Sport Compacts and other vehicles with 4- and 6-cylinder engines. Moroso’s Accumulator 2 (No. 23930) is intended for street performance and mild off-road applications, and features a 1.5-quart capacity.
All Accumulators store oil under pressure and automatically release that oil to the main galleries when oil pressure drops. Moroso Accumulators can also be used to manually pre-lube engines before starting to prevent cold-start scuffing and premature bearing wear.
Tilboðsverð 23,870.kr
Vagnhöfða 23.  S: 590-2000.
