Author Topic: B&M Skiptar  (Read 4113 times)
Offline Bílabúð Benna
    • Bílabúð Benna
B&M Skiptar
« on: November 19, 2008, 13:00:53 »
#80797
Street Bandit Hi-Tek
* Ideal for high-tech pro-street & street rod type vehicles.
* Narrow styled aluminum housing.
* Includes neutral safety switch, backup light switch and billet aluminum knob.
* Can be used with a reverse pattern valve body.
* Includes polished blade-style stick assembly for the Hard Core Street Bandit
* Includes polished Magnum Grip style stick assembly for the Magnum Grip Street Bandit
The Street Bandit is the ultimate shifter for automatic transmission-equipped street vehicles. Whether you are building a high-tech pro street car or street rod, the Street Bandit is the professionals' choice. The polished billet aluminum housing and the narrow styling are ideal for your vehicle. Cable operated and easy to install with a unique hidden mounting system are just a few of the features of the Street Bandit. Includes neutral safety switch, backup light switch and billet aluminum knob with engraved insert. The Hard Core Street Bandit is one sweet piece of shifter technology. It has the look and feel of our Pro Bandit race shifter. If you want to give your vehicle that race "vibe", but want to retain all the driveability of a street shifter - this is the shifter for you! The Magnum Grip Street Bandit (shown here) includes all of the standard Street Bandit features along with the new Magnum Grip handle CNC machined from billet aluminum. The design is clean, smooth, and functional, it has just the right look for your street machine!
http://www.bmracing.com/bmracing/installation_instruction/3.pdf
58,942.kr
#80855
PRO GATE
Pro Gate Whether it's for Stock, Super Stock, Comp Eliminator or bracket racing this is the racers choice. Engineered to be used with reverse pattern valve bodies. When used with an aftermarket electric solenoid, this is a true no hands 1-2 and 2-3 shift mechanism. Featuring a stainless steel stick, billet aluminum pivot, spring loaded reverse lock out, reverse pattern 3 speed gate plate and it is a rear exit cable mechanism. A neutral safety switch is included along with a 5 foot super duty race cable. The gate plate is easily changed to allow the shifter to function with a standard pattern three speed transmission.
The ultimate gate shifter for the serious three speed racer!
Supplied with 5' Super Duty race cable
    Fits: GM TH-400, 350, 250 & 200/ Ford C4 & C6/ Chrysler 1966 and later TorqueFlite A727 & A904
59,220,kr
« Last Edit: November 19, 2008, 13:15:38 by Bílabúð Benna »
Vagnhöfða 23.  S: 590-2000.
