Author Topic: Millihedd, knastįs og liftur fyrir Ford 351W  (Read 6270 times)
Offline Bķlabśš Benna
    • Bķlabśš Benna
« on: November 13, 2008, 09:27:43 »
Sett af milliheddi, knastįs og liftum frį
        #7181
Edelbrock Performer RPM. Designed for 1969 and later 351 Windsor Ford V8 high-performance engines with Edelbrock Performer RPM cylinder heads, modified OEM cylinder heads or equivalent. The dual-plane design offers good throttle response with excellent top-end power for the street. No provisions for choke or rear water crossover. Will fit 1964-1/2 to 1970 Mustangs. Will not fit under stock hood of 1974-78 or 1979- 95 Mustangs. Aftermarket 4-bbl carbs are not compatible with Ford Auto Overdrive Transmission (AOD) unless used with Lokar bracket SRK-4000, see note at bottom of this page.
Vinnslusviš 1500 - 6500 RPM
          #7182
ATH: Upplżsingar um Knastįsinn voru uppfęršar 18/4 09 vegna villu
Duration at 0.006" Lift: Intake: 290° Exhaust: 300°
Duration at 0.050" Lift: Intake: 224° Exhaust: 234°
Lift at Cam: Intake: 0.310" Exhaust: 0.325"
Lift at Valve: Intake: 0.496" Exhaust: 0.520"
Timing at 0.050" lift: Open Close
Intake: 06° BTDC 38° ABDC
Exhaust: 51° BBDC 3° ATDC
Centerlines: Lobe Separation - 110° Intake Centerline - 106°
http://www.edelbrock.com/new_products/
Tilbošsverš
Mllihedd              36,728.kr
Knastįs og liftur   19,064.kr
« Last Edit: March 18, 2009, 17:00:51 by Bķlabśš Benna »
Vagnhöfša 23.  S: 590-2000.
