Author Topic: FORD 6.0L 2003 – 2005. MSD Propane Injection kit  (Read 7169 times)
Offline Bílabúð Benna
    • Bílabúð Benna
« on: September 03, 2008, 11:45:49 »
MSD Propane Injection kit.
FORD 6.0L 2003 – 2005.  Tilboðsv:  66.815.kr
Ef þetta kerfi yrði pantað núna í dag það um 150þús :!:
Smá um kerfið:
When propane is injected into a turbocharged diesel engine there is a tremendous increase in power and torque! Power isn’t the only benefit as you’ll also gain travel range in your rig with the addition of clean burning propane.
MSD’s all new Digital Propane Injection system is the safest propane system available. That’s because MSD uses a closed loop ECM that constantly monitors the engine parameters, such as propane vapor temperature, over-boost and of course rpm, before any propane is allowed to be added to the engine. If the engine management parameters are not met, no propane is used. Or, if you simply do not want to use the system at certain points, it can be disabled with the flip of a switch. This system also has the capabilities to data-log a number of engine parameters.
When you’re towing a heavy load the new MSD DPI system will give you the extra oomph to get up and over the toughest grades. Not only will the power be increased but you’ll be able to run further between fuel stops.
On a 2003 Powerstroke the DPI System gained 76 hp and 150 lbft! Typical gains for the various kits average of 75 hp and 150 lb-ft of torque over the rpm range!
Each DPI system is programmed for each application so there are no jets to drill or external adjustments required. Supplied with mounting brackets and installation instructions.
Features and Benefits
• Greatly increase horsepower and Torque.
• Extended travel range between fuel stops.
• ECM monitors the engine parameters for safe and proper operation.
• Data log engine parameters to monitor system performance.
• System can be turned Off with a switch if desired.
Note: The propane tank must be purchased separately.
Vagnhöfða 23.  S: 590-2000.
