Author Topic: kawasaki ninja 07 100þús og yfirtaka  (Read 2200 times)
Offline puzzler
« on: August 15, 2008, 17:00:48 »
 %===Kawasaki==Ninja Zx-6R ==05.05.2007.Skipti skoða allt eða skjávarpa
Kawasaki Zx-6r
árgerð 2007
Ekinn :5000km
Skipti möguleg:skoða allt
lán hjá sp .
afb 17-21
aukahlutir
Power Commander er í pöntunn
Crash protectors
rearset raisers
_www.5150 Concepts.com
http://www.kawiforums.com/showthread.php?t=93304
Maxims dekk ný súper fljótt hitna
og fl í pm
áhvílandi ca 900kall eitthvað sollis
myndir líka í pm
smá info á ensku
he new ZX-6R was designed to take home trophies and set the quickest lap times, while being more exciting to ride than anything else in the middleweight sportbike category. The Ninja ZX-6R is a pure expression of Kawasaki’s racing philosophy.
We have not tested yet ths motorbike, but it is obviously a brilliant motorbike.
OK, it a little 600cc, ok it needs to take 192000 Rpm to fell power, but it is sexy and very efficient.
With 125 Bhp (131 Bhp with Ram Air) at 14500rpm for a maximum of 16500rpm.
Details review of this fantastic and promising machine:
Key Features :
- Incredible power-to-weight ratio
- Race-oriented performance
- Track-tuned handling
- Aggressive new aerodynamic styling
High-Revving 599cc Four-Cylinder, DOHC Engine:
- New compact, narrow and lightweight design features a tri-axis crankshaft and transmission shaft layout to optimize the engine’s center of gravity.
Four-Valve Cylinder Head:
- Compact valve train reduces cylinder head height
- Intake ports and coolant passages were developed using flow analysis for efficient cylinder filling, more power, and maximum cooling efficiency
- Forged sintered aluminum spring retainers are half the weight of steel retainers and allow higher rpm
Forged Pistons:
- Forged pistons are lighter, stronger and more heat resistant than cast versions.
Ram Air Induction:
- Central ram air duct produces a straighter path to the airbox for maximum intake efficiency and provides the mounting surface for the instrument panel, eliminating brackets and weight
- Flow analysis used to design efficient ducts to the airbox that also prevent water from reaching the air filter
- Compact airbox and air cleaner are highly efficient and contribute to the compact riding position
Digital Fuel Injection:
- Shorter ...
er selja vegna fjölgunar í fjölskyldu og kaupum á fyrirtæki ..
5643274-7706108
