Author Topic: 2008 Saleen STERLING #15 af 25  (Read 6295 times)
« on: July 10, 2008, 23:37:34 »
Þessi var að koma á göturnar, hrikalega fallegur 2008 Mustang Saleen STERLING. Þetta er afmælisútgáfa í tilefni af 25 ára afmæli Mustang Saleen.
Aðeins eru framleiddir 25 bílar og er þessi númer 15 og sá eini sem seldist utan USA. Bíllinn er með 302 vél (5.0L) með supercharger, og er 620 hestöfl.
Langar til að óska Hilmari enn og aftur innilega til hamingju með GEGGJAÐAN bíl.  =D>
Hérna eru nokkrar staðreyndir um bílinn.
VÉL:
  • 302 CID (5.0L) Modular, 3-Valve SOHC V8
  • 620 HP @ 6300 RPM
  • 600 lb-ft TQ @ 4400 RPM
  • 39 lb/hr Fuel Injectors
  • 3.554” x 3.800” Bore & Stroke
  • Port Matched Series VI Integrated Twin-Screw Supercharger
  • Heavy Duty Upgraded, Dual-Stage Water-to-Air Intercooler System
  • Saleen Cold Air Induction with Hi-Flow MAF & Conical Filter
  • Forged Aluminum Pistons, Forged Steel Connecting Rods, Forged Steel Crankshaft
  • 5-Axis CNC Ported Aluminum Cylinder Heads
  • Performance Camshaft
  • Aluminum Dual-Core Radiator & High-Flow Cooling System
  • PowerFlash™ Performance Calibration
  • 2.5” Stainless Steel Center Exhaust System
DRIFRÁS:
  • Close-Ratio 6-Speed Manual Transmission
  • High Performance Clutch
  • 3.73:1 MaxGrip™ Speed-Sensitive LSD
  • RACECRAFT SUSPENSION Sport-Tuned Coil Springs
  • (F/R) Sway Bars, 1.38" with HD Bushings (F), 0.79" (R)
  • Front Struts (N2), Rear Shocks (N2)
  • Watts Linkage Rear Suspension
BREMSUR:
  • Power Assisted 4-Wheel Disc Brakes with ABS
  • 15” Crossdrilled & Vented Front Disc Brake System with 6-Piston Calipers
  • 11.8" Crossdrilled & Vented Rear Disc Brake System
DEKK OG FELGUR:
  • Sterling Edition Forged Durabite™ Split 5-Spoke Wheels
  • 20” x 9” (F), 20” x 10” (R)
  • Ultra High Performance Pirelli P-Zero Tires
  • Tire Pressure Monitoring System
Ekki amaleg innkeyrsla.
8)
Stutt video --> http://www.youtube.com/watch?v=BMK01bVcIXM
Fleiri og stærri myndir má sjá hérna --> http://www.bilavefur.net/album/thumbnails.php?album=254
Frekari upplýsingar hérna --> http://www.gullospeed.com/sterling.htm
« Last Edit: July 10, 2008, 23:49:40 by Moli »
Re: 2008 Saleen STERLING #15 af 25
« Reply #1 on: July 10, 2008, 23:46:27 »
Bara svalt.......
til hamingju Hilmar....
« Reply #2 on: July 10, 2008, 23:52:37 »
Þessi var í skoðun um daginn þegar ég fór með trukkinn,hann er rosalega fallegur og fínn náunginn sem á hann.
« Reply #3 on: July 10, 2008, 23:54:24 »
Rétt Frikki, Hilmar er toppnáungi, gull af manni!  :mrgreen:
Offline R 69
« Reply #4 on: July 11, 2008, 00:00:36 »
Geðveikur bíll.
Sá hann fyrr í kvöld
 =D> =D> =D>
Helgi Guðlaugsson
« Reply #5 on: July 11, 2008, 00:12:40 »
já sæll!  :shock:
Offline Svenni Turbo
« Reply #6 on: July 11, 2008, 13:38:12 »
 :shock: Frikki  þó
Got BOOST? If it ain't blown, it sucks...
http://www.cardomain.com/ride/2080537
www.bilmalning.is
Offline doddizz
« Reply #7 on: July 11, 2008, 15:50:22 »
 :shock:GEÐVEIKUR :shock: til hamingju :worship:
« Reply #8 on: July 11, 2008, 18:12:16 »
 :shock: Frikki  þó
hér er gat og ég í það :-"
