Author Topic: 2007 Suzuki GSX-R600 (Yfirtaka á láni)  (Read 2626 times)
Offline kingpin
« on: July 02, 2008, 15:01:18 »
Eins og nýtt
599 cc. slagrými
Litur: Svartur
Beinskipting: 6 gíra
Strokkar: 4
Hestöfl: 118
Kg: 162
Ekinn: 3100 km
Yfirtaka á láni
Sími: 866-0517  Bjöggi
Átti ekki myndir þannig ég tók myndir af alveg eins hjóli af netinu.
Og lét smá upplýsingar um hjólið fylgja með.
SPECIFICATIONS.
DIMENSIONS AND DRY MASS.
Overall length: 2040 mm (80.3 in)
Overall width: 715 mm (28.1 in)
Overall height: 1125 mm (44.3 in)
Wheelbase: 1400 mm (55.1 in)
Ground clearance: 130 mm (5.1 in)
Seat height: 810 mm (31.9 in)
Dry mass: 162 kg (357 lbs)
ENGINE.
Type: Four stroke,liquid-cooled, DOHC.
Number of cylinders: 4.
Bore: 67.0 mm (2.638 in)
Stroke: 42.5 mm (1.673 in)
Displacement: 599 cm3 (36.5 cu.in)
Compression ratio: 12.5 : 1
Fuel system: Fuel injection.
Air cleaner: Paper element.
Starter system: Electric.
Lubrication system: Wet sump.
Idle speed: 1300 100r/min.
DRIVE TRAIN.
Clutch: Wet multi-plate type.
Transmission: 6-speed constant mesh.
Gearshift pattern: 1-down, 5-up.
Primary reduction ratio: 1.974 (77/39)
Gear ratios:
Low: 2.785 (39/14)
2nd: 2.052 (39/19)
3rd: 1.714 (36/21)
4th: 1.500 (36/24)
5th: 1.347 (31/23)
Top: 1.208 (29/24)
Final reduction ratio: 2.687 (43/16)
Drive chain: RK525SMOZ7Y, 114 links.
CHASSIS.
Front suspension: Inverted telescopic, coil spring, oil damped.
Rear suspension: Link type, coil spring, oil damped.
Front fork stroke: 120 mm (4.7 in)
Rear wheel travel: 130 mm (5.1 in)
Steering angle: 27 (right & left)
Caster: 23 45'
Trail: 97 mm (3.8 in)
Turning radius: 3.4 m (11.2 ft)
Front brake: Disk brake,twin.
Rear brake: Disk brake.
Front tire size: 120/70ZR17M/C (58W) tubeless.
Rear tire size: 180/55ZR17M/C (73W) tubeless.
Suspension.
Front: Inverted telescopic, coil spring, oil damped,
spring preload fully adustable, rebound and compression damping force fully adjustable.
Rear:Link type, coil spring, oil damped, spring preload fully adjustable,
compression damping 2-way fully adjustable, rebound damping fully adjustable.
ELECTRICAL.
Ignition type: Electronic ignition (Transistorized)
Ignition timing: 6 B.T.D.C. at 1300 r/min.
Spark plug: NGK CR9E or DENSO U27ESR-N.
Battery: 12 V 28.8 kC (8 Ah)/10 HR.
Generator: Three phase A.C. generator.
Main fuse: 30 A.
Fuse: 10/10/15/15/10/10 A.
Headlight: 12 V 55 W(H7)+12 V 65 W (H9)
Turn signal light: 12 V 21 W.
Brake light/Taillight: LED.
Position light: 12 V 5 W 2.
Speedometer light: LED.
Tachometer light: LED.
Neutral indicator light: LED.
High beam indicator light: LED.
Turn signal indicator light: LED.
Fuel level indicator light: LED.
Oil pressure / Coolant temperature / FI warning light: LED.
Engine RPM indicator light: LED.
Immobillizer indicator light: LED.
CAPACITIES.
Fuel tank, including reserve: 15.5 L (4.1/3.4 US/Imp gal)
Engine oil, oil change: 2200 ml (2.3/1.9 US/Imp qt)
with filter change: 2500 ml (2.6/2.2 US/Imp qt)
overhaul: 2900 ml (3.1/2.6 US/Imp qt)
Coolant: 2.7 L (2.9/2.4 US/Imp qt)
