Author Topic: ford  (Read 2949 times)
  • ef stórt er gott ţá er stćrra betra
ford
« on: June 22, 2008, 11:25:56 »
best á Camaro 1972 1,49 60 f 6,49 1/8  10,19 1/4 @ 131.96.  best á  Blower Camaro 1967 1,16 60 F 5,12 1/8 og 8,16 1/4 @169. best á Dragga 8,26 @ 170,97 en ţá voru ekki komnir 60 f timar. sandur 3,34 draggi og á hjóli 4,56 kveđja Kristján Skjóldal
Re: ford
« Reply #1 on: June 22, 2008, 11:43:01 »
nei Stjáni leifum honum ađ komast áfram og gefum honum 1000$ ţá getur hann keypt eina svona
The king of all Corvettes is the amazing 2006 ZO6. It tops out at 198 mph, runs the quarter mile in 11.5 seconds at127 mph, and hits 60 mph in a jaw-dropping 3.5 seconds (in first gear). All of that performance is the result of superior GM engineering and an engine we call the LS7, the most technologically-advanced small-block ever built. A natural continuation of the LS Family, the LS7 uses a 7.0-liter aluminum dry-sump block, CNC-ported cylinder heads, and titanium rods and valves to pump out 505 hp and 470 lb.-ft. of torque. Talk about efficient, the LS7 helps the 2006 ZO6 get over 28 mpg while still being the fastest Corvette ever produced! Is this the Chevy small-block in its highest form? Only you can decide, and GM Performance Parts has made it that much easier by offering the already legendary LS7 as a complete crate engine, ready to bolt into your favorite project car.
TECH SPECS:
Engine type: Cam-in-block 90-degree V8
Displacement (cu in): 427 (7.0L)
Bore x Stroke (in): 4.125 x 4.00 (104.8 mm x 101.6 mm)
Block P/N 17802854: Cast aluminum w/6-bolt steel main bearing caps
Crankshaft (P/N 12568819): Forged steel
Connecting rods (P/N 12586258): Forged titanium
Pistons (P/N89017774): Hypereutectic aluminum
Camshaft type(P/N 12571251): Hydraulic roller
Camshaft lift: .591" (15 mm) Intake and Exhaust
Camshaft Duration: 211ˇ intake / 230ˇ exhaust
Cylinder heads (P/N 12578450): CNC Ported LS7 specific pattern 70 cc CNC combustion chambers
Valve size (in): 2.20" titanium intake, 1.61" sodium filled exhaust
Compression ratio: 11.0:1
Rocker arms: Investment cast, roller trunnion
Rocker arm ratio: 1.8:1 (offset intake only)
Recommended Fuel: 91 octane
Maximum rpm: 7,000
Reluctor wheel: 58X
Re: ford
« Reply #2 on: June 23, 2008, 16:07:27 »
ţađ er nú no brainer ađ taka fordinn í ţessum samanburđi..
Besti tími í kvartmílu. 10,697  60ft. 1,543  hrađi. 114,5mph
Besti tími í 1/8. 6,526  60ft. 1,865  hrađi. 117,5
Kveđja, Stefán Steinţórsson
