Author Topic: 4.2" Dvd spilari með snertiskjá og bluetooth SELDUR!!  (Read 2543 times)
Offline budapestboy
« on: March 10, 2008, 19:18:54 »
Upplýsingar um tækið.
Wide 4.2 Inch LCD Screen with High Resolution of 960*234
Compatibe with DVD (-R/-RW/+R/+RW) / VCD / SVCD / MP4 / CD / MP3 / WMV / WMA / JPG
Built-in TV Tuner (PAL/NTSC Switchable)
High power amplifier, output 4x 45W
Super Anti-shock System
AUX Audio Input / RAC Video Input & Output / 2 RCA Audio Output
Video System: NTSC / PAL / Auto
Screen Mode: 4:3 and 16:9
Multi language OSD Menu
Multi System, Language, Subtitle, Angle, Audio, Video Setting
Electronic Volume Control (Treble, Bass, Balance, Fader)
DSP Preset EQ / Rock / Jazz / Classic / Pop
Dolby Digital Setup
Play back control menu list
FM / AM Stereo Receiver
30 Preset Memory Stations
JPEG Image Browser. Slide Show, zoom, pan function
Mute / Clock Control
Full function , card size remote control
Touch Screen
Manual Control Panel
Bluetooth Technology Inside - work with cell phone as keypad
USB/SD Card Reader
Specification: wd9686
General
Power Requirements: DC 12 Volt
Faceplate not detachable
Max. Power Ouptut: 45W x 4
Tone Controls: +/- 8dB (Bass 100Hz, Treble 10KHz)
Gift Box Size: 280 x 210 x 101mm (L x W x H)
Cartoon Size: 480 x 290 x 230mm (L x W x H)
Weight: 1.85Kg
FM Tuner
Frequency range: 87.5 - 108.0 MHz
IF Range: 10.7MHz
Usable Sensitivity: 15dB
Signal-to-noise Ratio: 50dB
Stereo Separation: 30dB
AM Tuner
Frequency range: 522 - 1620 KHz
IF Range: 450KHz
Usable Sensitivity: 25dB
Amazing Bundled Accessories:
Brand New 4.2 Inches In Dash DVD Player
Remote Controller
Power Connector
User Manual
USB cable
Audio/Video connecting cable
Mounting accessories
I / O Parts:
TV Antenna Input (compatible with our antennas)
FM Antenna Input
Audio Output (L&R)
4.0 Speaker Output
Audio Input (L&R)
Video Input
Video Output
Svaka græja með snertiskjá og bluetooth sem tengist við farsímann spilar allt mögulegt og er sjónvarp líka vantar bara loftnetið (þarf að kaupa það sér).
Fæst á 25 þúsund.
Sími 8689646 Óskar
