Author Topic: /////HAULMARK ////// Yfirbyggð kerra.  (Read 3264 times)
Offline JHP
    • http://CORVETTE.IS
« on: February 12, 2008, 00:08:23 »
Nýskráð 18.10. 2004
Skemmd á hægri hlið.
Lítið mál að fá alla varahluti.
Verð 500.000
Uppl í 8204469 - PM eða nonnivett@corvette.is
Exterior
Length: 12ft Long
Width: 6ft Wide
Interior
Loading and Towing
2,000lb Tongue Jacks: 2,000lb Top Wind Tongue Jack
Hitch Type: Tag
Jack Accessories: Sand Pad
Safety Chains: 5,000lb Silver Safety Chains w/S Hook
GVWR: 2990
Suspension
Tires: ST205/75D14 C Rated Tires
Wheels: 14in 5 Hole White 8 Spoke Steel Wheels
Axle Width: Standard Track
Hub Type: EZ-Lube Hubs
Suspension: Spring Suspension
Weight: 3,500lb Axles
Doors
Construction
Cap: Polar White Cap
Crossmember Spacing: Crossmembers 24in On Center
Crossmembers: Z Crossmembers
Finish: .030 Aluminum Exterior
Roof: 1-Piece Aluminum Roof
Roof Bow Spacing: Roof Bows 24in On Center
Roof Bows: Tube Roof Bows
Sidewall Liner: 3.6mm Luaun Sidewall Liner
Top Wrap: .080 Aluminum Top Wrap
Vertical Post Spacing: Vertical Posts 16in On Center
Vertical Posts: 60-3/4in Z Posts
Additional Specs
A-Frame Couplers: 2in 5,000lb Coupler
Bolt Pattern: 5 Bolt Pattern
Frame Type: Steel Frame
Hr Jón H Pétursson
Trans Am GTA ´88
Corvette coupe ´95
Corvette coupe ´92
