Author Topic: Bremsuklossar f. Camaro 98-02  (Read 2564 times)
Offline Skari™
    • http://www.camaro.is
« on: February 04, 2008, 22:54:11 »
Fékk vitlausa klossa senda fyrir bílinn minn. Þetta eru Hawk Performance bremsuklossar
Og það sem er skrifað um þá:
No matter what level of brake system you Camaro possess, a performance brake pad is the final link. The Z-rated compound has better bite in cold weather conditions and less fade when used in extreme or hot race conditions. This is possible because the Z-rated pads have a higher friction coefficient than OEM brake pads and operate at higher heat ranges, which reduces brake fade. The Z-rated pad is designed to conform to your specific driving style. Moderate dust should be expected when a performance brake pad is used on a daily basis.
Set á þetta 5þús kall
« Last Edit: January 27, 2011, 06:51:25 by Skari™ »
Óskar F. Júlíusson
Chevrolet Camaro Z28 LT4 '95
Buick LeSabre Limited 350 V8 '81
Suzuki RM-Z 250 '05
www.camaro.is
