Author Topic: Intercooler  (Read 3533 times)
Offline Hafþór Jörundsson
  • I'm new in the fuck you business
Intercooler
« on: January 10, 2008, 22:47:38 »
Water to Air Intercooler Drag Racing 10"x9"x4.5" 1200HP
Brand New...100% Aluminum, hand welded, constructed with a bar and plate design. Polished finish intercooler. Perfect for your next turbo project or upgrade. Buy direct from importer and save BIG.
Air/Liquid intercoolers run by pumping cooled water through cores either from a front-mounted radiator / heat exchanger or chilled water produced by circulating the liquid through a container filled with ice, as used in quarter mile applications.
Good for up to 1200bhp. all our intercooler has been tested to withstand more then 80 psi pressure and it has very small pressure drop across the end tanks, at 15psi inlet the out let has 14.8psi that means it has only 0.2 psi pressure drop ,compare to many other intercoolers it is an excellent figure (some intercooler has 1-2psi pressure drop) also at the same condition, the temperature has drop from 120 degree to 28 degree ( and it is an excellent figure for efficiency)
Core Length :9"
Core Height:10.5"
Core Thickness:4.5"
Inlet Size:3"
Outlet Size:3"
Overall size(with endtank): 16.50"x12.8"x 4.5"
Hafþór Jörundsson
S:898-5811
Re: Intercooler
« Reply #1 on: May 19, 2010, 21:55:47 »
Enn til.
Hafþór Jörundsson
S:898-5811
Re: Intercooler
« Reply #2 on: October 10, 2011, 02:05:40 »
TTT
Hafþór Jörundsson
S:898-5811
Re: Intercooler
« Reply #3 on: October 19, 2011, 05:11:47 »
TTT
Hafþór Jörundsson
S:898-5811
Re: Intercooler
« Reply #4 on: October 24, 2011, 15:00:55 »
TTT
Hafþór Jörundsson
S:898-5811
