Author Topic: SBC  (Read 2611 times)
SBC
« on: October 15, 2007, 22:46:28 »
Nýr Comp Cams Knastás 268H  og Nýjar Liftur Sealed Pro
Flott lausagangshljóð
Basic Operating RPM Range:    1,500-5,500 RPM
Intake Duration at 050 inch Lift:    218
Exhaust Duration at 050 inch Lift:    218
Duration at 050 inch Lift:    218 int./218 exh.
Advertised Intake Duration:    268
Advertised Exhaust Duration:    268
Advertised Duration:    268 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:    0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:    0.454 in.
Valve Lift with Factory Rocker Arm Ratio:    0.454 int./0.454 exh. lift
Lobe Separation (degrees):    110
Verð:10þús
Nýjir TRW Stimplar 4.030 húðaðir á hliðum og chomemoly hringjasett á Stock 5,7 Pink stöngum
Sveifarás með 3,48" slag 0,10 höfuðlegur og 0,20 Stangarlegur
Nýlega rendur og lítur vel út
Tvöfaldur Roller Tímagírshjól og tímakeðja
Balancer
Flexplata
Verð:30þús eða tilboð í pakkan
S:8684789 eða Pm
