Author Topic: Rúlluknastás í sbc til sölu SELDUR  (Read 2861 times)
Offline Hilmarb
    • http://www.cardomain.com/ride/820137
« on: October 14, 2007, 21:40:43 »
Nýr í kassanum Comp Cams 08-422-8 rúlluknastás í 87- sbc (passar í original rúlluvél)
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Part Type: Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,600-5,400
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.502 in.
Valve Lift with Factory Rocker Arm Ratio: 0.495 int./0.502 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: CS XR270HR-10
Quantity: Sold individually.
Camshaft, Hydraulic Roller Tappet, Advertised Duration 270/276, Lift .495/.502, Chevy, Small Block, Each
Check to make sure this part fits your application
Get Xtreme performance from COMP Cams.
COMP Cams Xtreme Energy camshafts are built to take advantage of the latest cam technology, to provide maximum performance. Whether your use is off-roading, towing, or street performance, there is an Xtreme Energy cam available for you. By using an aggressive lobe profile, these cams provide better throttle response and more top-end horsepower than equivalent cams from other manufacturers, while delivering increased engine vacuum.
Hilmar Björn Hróđmarsson
_______________________________________
